This came up in another
thread of mine in the DIY forum. I wanted to post it here because this section gets more traffic.
Is it at all feasible to run a 4 OHM Advent Smaller Loudspeaker off the center channel amp of my Panasonic SA-HE100 receiver? Any receiver?
I am having second thoughts on being able to build speakers that will sound better then the Advents with my current budget constraints. I could pick up a pair of identical Advents on Ebay for not too much money. I would have a matched system to hold me over until I can afford to build some very nice DIY speakers.
Would I end up blowing up my receiver if I tried this? It does say in the manual, as in all receiver manuals I've seen, not to connect 4 OHM speakers to anything other than the main L/R channels.
EDIT: OK I was curious enough to take one of the Advents and hook it up to the center channel. I connected the center channel where the Advent was.
WOW! It sounds so much better this way. The Advents have
much better and smoother highs without the extreme silibance I hear from the Polk, which is way too bright. Voices are much more natural. My guess would be that the Polk has some significant frequency peaks/dips that make male voices thin and female voices harsh. The Advents are simply superior.
I have played some loud scenes from Bourne Supremacy and Lord of the Rings and have not seen any ill effects. The receiver isn't getting any hotter than normal and it isn't going into protect mode. I think I might just have to go for the Ebay speakers which are available for local pickup.
