8 speaker system replacement.
jpv
I have a open area of around 5m x 15m with 8 in ceiling speakers. I want to replace the speskers with a bluetooth connected one. As like arylic a50. As long as all 8 plays in sync and can be streamed. Any suggestions?
everettT
everettT
You have power to all 8 locations? If so you can use a Streamer like the WiiM Pro to connect to several Bluetooth or WiFi speakers. This will likely get expensive though.
Eppie
Eppie
That's not enough information to go on. Can you remove one of the speakers and get the exact make and model number? Do you have separate wires runs from each speaker to one location or are the speakers connected in a daisy chain fashion? There are two styles of in ceiling speakers. Regular home speakers that are typically 8 ohm and commercial multi-room speakers designed to run off a 70 volt system. The type of speaker and wiring will dictate what you can do.
BMXTRIX
BMXTRIX
No, you really don't want to replace the speakers. You just need amplification for the speakers that are already installed, and then you can add a streaming device to it which uses WI-FI, NOT Bluetooth. You will get better reliability and performance using a proper streaming device. Bluetooth is lower quality and was never meant for the type of use you're looking for. It's literally mean for headphones connected to phones, and has evolved greatly, but still isn't the right way to do home audio at all if it can be avoided.
