8 ohms speakers to 4 ohms amp??
Yohansen
Yohansen
You may be right, I hust never had plugged them to 300w amp.
I use the RTIA7 paired with Yamaha receiver. They sound good.
Any advice on how to position them?
Thank you
Andon
Andon
This will all depend on you room. How it is shaped and how big it is?
HTfreak2004
HTfreak2004
I need help with 2 channel set up
Thank you for your response
What’s your room dimensions?
Is this an open concept or dedicated room?
Are there walls creating a sound stage such that the both speakers are gain equal amount from the boundaries?
You don’t want one speaker corner loaded and the other practically in open space( and I wasn’t recommending corner loading just an example)
How far would you like to sit from your speakers?
