MDS:
MDS said:
Calibrating to reference level doesn't imply anything about A vs C weighting. You use C weighting when calibrating but the choice of 75 dB vs 85 dB depends solely on the average level of the test tone.
What standard dictates that all receivers use a -30 dBFS calibration signal? Presuming there is such a standard, is it safe to assume all receivers are adhering to it? The only reason I ask is because the Dolby literature I've been going through appears to
imply a "standard" of -20 dBFS for pink noise calibration. But I am not familiar with what standards, if any, would govern this sort of thing. Any thoughts?
You also mentioned earlier in the thread that:
...the average level of the soundtrack of a movie on DVD is -31 dB...
There would appear to be ample research that suggests this isn't the case for all DVDs. So is this a standard by which DVDs
should be produced, or is it actually the case for all DVDs?
Please note that I'm not trying to be a d1ck or anything. Just trying to understand this better myself!
Koila:
Am I missing something? Who cares if -14dB on the receiver’s display is actually 75dB from each channels?
Others may feel different, but, IMO, it is always best to have the signal level well above the noise floor and, at the same time, have it set such that program material will not send your amp(s) into clip. If you set the reference too low, you run the risk of getting too close to the noise floor of the equipment. Granted, this is an unrealistic scenario for most equipment these days since the amount of gain trim on a given channel is usually limited to 10-30 dB (looks like about 12-20 dB on your Yamaha).
The other problem, that of clipping, is very real. If you decide, for example, to set the highest possible master volume level (+16.5 dB on your Yamaha receiver) as the "reference," then peak levels in the program could clip your amplifiers. Not pretty.
Bottom line is there are sound reasons for using 0 dB on the master volume as the reference level. Listening at 85 dBC (or 75 dBC for that matter) is probably not going to be comfortable. Thus, if you set "reference" to -14 dB on the master volume, you may find that your comfortable listening level is somewhere south of that. Whereas setting "reference" to 0 dB on the master volume allows you to get more S/N, but still not run the risk of clipping. Again, this may not matter much in the grand scheme of things - equipment S/N ratios are comfortably high these days (<80 dB on your Yamaha). I have, in the past, set "reference" to -15 dB or thereabouts on different receivers and had no problems with the system.
Make sense?
