I have been plagued with subwoofer hum in two different houses. It started in our old house, soon after I purchased a Denon and Paradigm system from my local shop. I tried everything to eliminate the hum, based on information widely available on the web, but ended up bringing my Paradigm sub back and basically trading it in for another one. My current is a Paradigm PDR-10 v.3, auto on and off, with spring loaded speaker input jacks and one Low Level Input RCA jack.
Same problem. It comes and goes, sometimes it's great, sometimes its awful. This is definitely not a low-level hum, but more of a loud, feedback sort of hum. Sometimes rearranging cables works, sometimes it gets worse. Sometimes just plugging and unplugging or turning the system off and on will help but it always comes back. I've tried to isolate it by unplugging one component at a time, including my cable tv coaxial, but there's no clear association between any of the components and the hum.
I'm using a Monster Clean Power HTS3000 for all electrical, which is then plugged into a grounded outlet so I don't see where I would be causing a ground loop. And trying to keep AC and signal cables apart doesn't seem to work either.
All of a sudden, I looked at the subwoofer cable that my guy sold me with my system 3 years ago- it's marked "75 Ohm Coaxial."
When I do a search for "subwoofer cable" it seems to me that most of the subwoofer cables out there are not 75 Ohm Coaxial, they are simple audio cables with RCA jacks on either end. Could it be that there's something with the 75 Ohm cable?
