720p with a low throw ratio ?
samaey
I'm looking for a 720p projector with a really low throw ratio (distance/width) to use it at a distance of 5m from the screen. Most vendors focus on native resolution, brightness, contrast and picture quality but it seems hard to find a machine with a good zoom lens.
BMXTRIX
BMXTRIX
What size screen are you looking to get from that distance? From 14 feet lens to screen there are dozens of projectors that can give you a 120" diagonal image - which is pretty darn big for that distance.
Why do you want such a large screen? Where will you be sitting? Have you looked under "Find Projectors" at Projector Central?
I think the Panasonic PT-AE900U does very at short distances. You didn't mention your screen size. With the AX100 out now ( I am reviewing it this very week) you're certain to get a good price. See if VisualApex has any left in stock.
