diggerdave
Is the yami 2500 worth $200 more than the 5790. if you think so. I'd be interested in knowing why...
thanks
dave
thanks
dave
clt1bkc said:This unit comes with a remote. Even if your comment was true on the knobs wearing out - Don't most use a remote. I have the HTR 5790 and rarely use any of the knobs on the unit. Not for the reason you stated but mine came with a remote!
Nomo has a valid point here. The RS232 port is only for upgrades, not for use as a general input, but it will let you keep up with the Dolbies and DTS's for the next couple of years without having to buy yet another receiver.NomoSony said:The 1400/5790 do not have RS232. 1500/2400/2500 do. I can't comment on how useful they really are at this point as I haven't used it.
WARNING: if you do buy Acoustic Research cables off E-Bay, don't get them from a company called moosedirect or mooseco unless you live in Illinois and can go pick up your cables with a shotgun in each hand. They are currently under investigation by the IFCC (case number I04111019359929) for taking people's money and never delivering the product.armaraas said:Another brand of cables that I like are Acoustic Research, best buy sells them instore, but I usually buy them off of ebay where you can get them for about half the price, usually $10 or less.
