5 Reasons Dolby Atmos May Be DOA
Auditor55
Auditor55
Putting in ceiling speakers when the wall is open is not a big deal. I recently added a family room addition with a vaulted ceiling to my old house. The room is reasonably well suited to 7.1.4 so I added in ceiling speakers and wiring for surrounds.
The downside, which I hadn't thought through, is now I need to power 11 speakers. Whoops. I think I'll wait a couple of months and see if Denon refreshes their high end models.
Why? Denon supposedly gives true power rating to their higher end receivers, so no external amplification is really necessary. Why not just get an eleven channel receiver?
VonMagnum
VonMagnum
If you like throwing your money down the drain, go 11 powered. It's far cheaper to go 9 powered with one external amp. There are two channel amps good enough for surround or height for around $60.
dzzmiller
I ended up buying the X3600H (9 channels powered) and I am using some older amps to power the front channels and zone 2.
Surprisingly my 35 year old Nikko Alpha II amp still works. The cost of 7.1.4 wasn't as bad as I expected. Not I need to figure out if I should connect my sources to the TV or the reciever.
panteragstk
panteragstk
Receiver. Always receiver.
snakeeyes
Yes. Agreed.
Not sure what TV but only concern is if Samsung 4K HDR10+ format or if anything 8K format. Those would be an issue on 2019 AVRs. These both will get support in the 2020 gear. (Yamaha announced already, so 99.9% Denon/Marantz as well). :)
panteragstk
panteragstk
Gotta have a source that supports it or if t doesn't matter. It's my understanding that at this time there isn't any of that content. If I'm wrong a source would be neat to see.
snakeeyes
Maybe I’m misunderstanding the tech but there are 4K Panasonic players that can play 4K HDR10+ content that cannot pass through current AVRs to the TV. You could certainly run audio to AVR and Video separately, direct to the TV. Any Samsung TV owner with HDR10+ might want that.
As far as 8k, there’s no content yet I’m aware of but there eventually may be some at some point and 8K video would need to go through HDMI 2.1 and those AVRs aren’t available yet. 8k today is more of an upscaling than a format with native content
If anything can be done in software, that’s news to me.
Technology certainly changes and there’s no sense in never buying but we are soon to see both of these features in the 2020 Yamahas in June or so. There’s links to it on this forum. I would probably assume the other manufacturers will have the same.
Yamaha thread here.
And the link goes to source here:
panteragstk
panteragstk
Yamaha thread here.
Yeah, I get what you're saying, I just didn't think any HDR10+ or 8K content was out there yet so it kinda sorta doesn't matter yet.
Looks like Amazon has HDR10+ content, but it apparently doesn't differentiate between that and plain old HDR10 in their list of titles/formats.
That and the fact that the HDR10 standard brightness is 1000 nits (which a lot of TVs aren't even capable of) then HDR10+ 4000 nits is pointless.
So, if you have a source and display capable of HDR10+ then plug them into the TV. Other than that Receiver.
Thanks for the links. Learned something new today. :)
snakeeyes
Ya there are also some UHD Blu-rays with 4K HDR10+
Here’s a link:
dzzmiller
I'm about a week into 7.1.4 in a new room. The $20 D&M equalizer app certainly improved the experience today.
I suspect I would have had about equal enjoyment going to 5.1.2. But I'm too lazy to experiment.
I've used Denon/Marantz for two decades. I don't know why the crappy interface and documentation still surprises me. Why zone 2 plays in some modes but not others is a mystery. Why the sub doesn't have a signal in stereo mode is a mystery.
panteragstk
panteragstk
There is a separate stereo setup on my 4300h when doing the speaker setup. Does yours have that too?
dzzmiller
Thanks. I found that I had the sub set to LFE only. So the sub is on now in stereo mode.
What I still don't like is that I don't seem to have control of when the reciever will use all 11 main channels and cut out zone 2. I would like to tell the receiver to do a real 5.1 and leave zone 2 on.
If there is an actual Atmos signal I'm fine with the recceiver cutting out zone 2.
panteragstk
panteragstk
Not going to be much help there. I don't use multiple zone capability on any of my receivers.
