After a considerable amount of time was spent in my options for this pickle, I thought it best to seek help from more technologically minded folk. I know audio leads are called AV leads and composite audio and vision leads are also sometimes called this but I thought it best to list the colours too so that you know that I know what it is I'm looking at
I bought a CJC 5.1 surround sound system and found that the cables provided were less than ideal as they were RCA to stereo jack. See cjc 5.1ch-speaker-subwoofer-system in
dealsdirect.com.au for specs.
Any suggestions would be much appreciated.
Ideal setup for surround sound
Xbox OUT to Tv IN, then Tv out to Surround sound IN.
Barriers-
Nowhere to plug in 3.5mm jacks that were provided with surround sound.
Input has 6 female RCA for surround sound, Output has 2 male RCA avail
Cables provided- stereo 3.5mm jack to Red and White RCA (x3 cables for centre/sub, surround & front speakers)
Inputs avail TV - Red, White and Yellow RCA
Outputs avail TV - Red, White and Yellow RCA
S-Video
Inputs avail Surround sound- Red and White RCA (x3 for centre/sub, surround & front speakers
Output Xbox – exclusive Xbox plug to Composite Video + Audio RCA
Ideas
Using the Xbox RCA audio cable and Y adapters-
Red and White audio cable split to multiply to make R2 (x2) and W2 (x2)
One R2 and One W2 is split to multiply to create R3 (x2) and W3 (x2)
The other R2 and W2 are left as is or extended for neatness
End result 6 RCA male for surround sound input
