4ohm speaker for rear, bad for receiver?
Spiffyfast
Spiffyfast
I found an older pair of bookshelves, no brand on them, just a sticker that says 4ohm and the wattage. They sound pretty good and I plan on using them for the rear channels. Can I drive these with my 1015tx without putting too much of a strain on it? I figure they are only rear channels so they won't get much of a use anyways, its not like they are mains and are used constantly. But, if this is something I shouldn't do, I'd like to know if I need to run a seperate amp for them as I have a 100x2 kenwood amp I could use, but don't really want to. I don't have enough speakers to run 7.1 without them as I am selling my old HTIB system to pay for my new cadence sub, and 5.1 just doesn't cut it anymore.
MacManNM
MacManNM
No problem. That unit can drive those all day long.
Blundaar
I'll remember that when I drop my resistance to 6 ohms on my entire set-up !! (begins crazy, mad scientist-type, laughter ) :eek:
I'm running 4 ohm surrounds too, and moved to them from smaller 8 Ohm versions from the same line. I was concerned about it being an issue when I bought them, but my receiver doesn't seem to get much hotter than it did before, so I think you should be OK. Running with an 80Hz x-over.
