Sleestack said:
The plasma does 720p and 1080i right?
With future HD formats still have 720p and 1080i formats available? I guess I'm wondering how long it will be before 1080p is widely used? If its 6 months, 1080p is important to me. If its 2 years, its not.
What about the XBOX360?
Are plasmas ok for the occasional video game?
Yes, all plasmas that I know of, accept 480i, 480p, 720p, and 1080i except for a few cheap models that may not accept 720p. By cheap, I mean, sub $2K models.
It is very important that you understand the just because a display IS 1080p native, does not ensure that it accepts a 1080p input! As crazy as it sounds, most 1080p displays do not actually accept 1080p input resolution which means that when HD discs come along with 1080p capability, the display will NOT be able to accept it.
Go figure.
For that matter, just because a display isn't 1080p doesn't mean that it won't accept a 1080p input into it. It really depends on the manufacturer and the processing they put on board.
BOTTOM LINE: There is not much in the way of 1080p content right now and while HD discs MAY offer some films at 1080/24p, those players will likely have internal conversion to 1080i or 720p. We are likely to have only 1080i and 720p broadcast television for the next 10+ years and I consider 1080p to be nice, but not nearly as important as a quality display with an excellent image.
Keep in mind that most front projection systems with a 10 foot image use 1280x720 displays, not 1920x1080. That's over twice the size of what you are talking about, and it is enough to make them very happy.
Video gaming is fine on a plasma as long as you are aware of burn-in issues. You just don't want to leave a stagnant image up on the screen for extensive periods. A couple hours? Fine! All day? Not a good idea. Many games these days are designed with lower contrast areas for score or areas that don't stay on screen all the time. It helps to prevent burn-in for sure.
For the first hundred hours or so of use you really want to put the plasma through a 'break-in' period as well which will help to eliminate burn-in issues.
Personally? I think plasma simply delivers a better image for the money. That's what is really important to me.
