musiclifeline said:
Hey all,
I've got a pair of B&W DM610i speakers (4 ohms) and a Harman Kardon HK3480 receiver (8 ohms)... Each speaker has separate pairs of inputs for high and low frequencies, and I'm wondering whether it would fry anything if I connected my receiver's A channels to the low frequency speaker inputs and the B channels to the high frequency inputs.
Would this be presenting too much impedance? I've got plenty of ventilation around the receiver...
Thanks,
m
H/K has always prided itself on its drive capabilities, and in most cases, rightly so. I own two of their integrated amps (6550, 2x50/70W into 8/4 ohms from 1994 and 680, 2x85/130W into 8/4 ohms from 1999), and can attest that their capabilities, especially those of the 680, are prodigious. It will pump out 540 watts into just 1 ohm in short term bursts, indicating extreme stability, and it will do so with just 10 dB (3:1) of negative feedback. My own design philosophy is based on some of their views since 1975.
That said, I should point out that the 3480 is a different story. It's a product made for the mass market, and while it does embody many of H/K's design principles, it is not up to the job of a true H/K.
I know it both outside and inside. In simple terms, it lacks the wherewithall to deal with complex loads the way its admittedly costlier bretheren do. It was made with the price as the ruling guideline, and since it must satisfy certain principles of its receiver breed, less was left for under the hood.
Therefore, while it will drive 4 ohms loads such as the 601s without adverse effects in electrical terms, its sound will not be what it should be. Taxing loads will dry up its moderate power supply and its just as moderate output stage, so deep bass will not sound as very deep, and there will be progressively more and more muddle up in the mid and high range. Unfortunately, the 601s are a taxing load, there are worse, but most are more gentle.
There are two ways you can deal with this. One is to change either the speakers or the receiver - obvious and probably not preferable. The other is to obtain a good power line filter; this will clean up the mains mess and thus offload the power supply, making it more efficient and allowing it to function more as a power reservoir than a filter.
The uknown in all this is how hard (loud) is the system required to work. If it is driven relatively gently, the problems will decrease, and conversly, if driven hard, the problems will increase. If your AVERAGE dissipated power is 1-2 watts, which is fairly loud with those speakers, your peaks will be around 30-50 watts, a range still within the capabilities of the receiver. Louder than that and the sound starts to deteriorate fairly quickly.
Cheers,
DVV
