4 Ohm Speakers/Reciever Combo
jostenmeat
Please note that the NAD high end power amp (M25) is 2.5 times more expensive than the Onkyo TX-SR805. Its power output into 4 ohms beat the 805 by less than 1 dB. I know it is not fair to compare a separate power amp to a low price receiver but it does show Seth made a valid point, in terms of $/W at least, in a compelling way.
Those tests were done at 1Khz signal only which is industry standard. I would like to see these test resuts run either full spectrum or at lower frequencies, sort what these guys did;
That Onkyo has a beast of an amp though from what I've read so far.
Yeah. I own both the 805 as well as a NAD mch amp. I am a bit of a regular contributor to the 805 owner's thread at AVS, and these are my impressions: Many users are quite surprised at the power the 805 can muster. However, there are still a few who have sent their unit into protection mode. A couple of these folks simply are more careful with their volume settings, or what they can expect. Some others intend to add outboard amps.
Of those who responded to a query about the volumes obtained at said thread, I'm pretty sure I require the most power. I obtain volumes closer to reference than nearly all other 805 users, and I do so with significant distances from speakers in a big room. While my speakers do drop in impedance, they do have good sensitivity.
805 offers plenty for most folks. Definitely not all though. While my NAD now has issue with one channel, I've never once put it in protection mode, and I don't even remember the last time I triggered its fans. Probably last year at some point. My anecdotal offering leads me to believe the NAD has more of it where it counts, and enough to make a real difference. As BS as that sounds. :eek:
In that page I can't see their benchtest reports, they must only briefly mention it, or I am not looking hard enough.:(
There used to be a way to view it in full screen without saving it first but something has changed and I no longer how to do it. If you click the disk icon to save it first, then you can view it in full screen and it will be much easier to navigate the pages and see the lab report.
Jeff R.
The driver that has the issue is the 4" driver. My others are the two 6.5"s. So really can not swap it out. I will keep searching for now. I have a sales man from yawa looking for me to see if they can get access to any drivers or reconing kits. I also told the guy from Yawa, I would consider buying a new tower if they have one that is significantly damaged and I would just use it for parts. I may end up taking you up on you offer for assistance TLS.
Thanks for the help guys.
Jeff R.
All who assisted with ideas on repairing my 4" midrange. Thanks again. I just got in contact with the old MB Quart speaker facility in Germany and they do have a replacement driver available. So it looks like I can just purchase a new 4" and swap it out with my damaged one. I will keep you all posted on it, especially on how well the 805 can handle powering these two MB Quart Towers. I think it will do just fine though. I have been listening to in quite bit so far and it runs a little warm, still plenty cool to touch. I will push it hard and long over the holidays so it will be a good test.
