Well, I've listened to some things now and think it does need some more tweaking. One thing that confuses me, if I check the EQ parameters after doing the auto setup, they are wildly different for the front L and R speakers! Not only completely different in their settings, but also in the frequency steps that are used. Does this make sense?
Just as an example. In the "normal" setting the selected Freq are:
For L: 50,100,160,570,1.0k,1.4k etc
For R: 50,80,130,250,640,1.4k,3.2k etc
does this make sense? My room is very different on each side, left has a bookshelf about 3 or 4 ft from the speaker, r has a long wall of windows and a couch. Surprised me to see this difference.
Plus an other question and maybe somebody can just point me to the right instructions, I have the digital Radioshack meter but I don't understand why I'd want to hook it up to the 3805 with a cable?
Man, this is a lot more complicated than I thought it would be
Would it make sense to buy a test CD or DVD?
Thanks!
Oliver
PS: as for the sub distance, the manual says that "speakers with built in filters such as subwoofers might be set with a value that differs from the physical distance because of the interna electrical delay"
Doesn't say to set it to the real distance which - in my case - is some 12 ft less than the auto measurement set it at.
Would you change it to the actual distance?
