Dear experts,
After several hours spent reading, studying and testing my speaker this is the result. I would have your feedback on the outcomes and my assumptions. What I would to do is something like John Lenard Burnett describes in his education articles (
http://education.lenardaudio.com/en/06_x-over.html)
I understand and appreciate your comments above, and would know what do you think on a different approach, supported by measurements and Mr. Lenard experience. I think most of us are here for learn and become more creative without real life company profit and time constrain…
so again, I will really appreciate your feedback and pro/cons on my project.
I’ve added another woofer, so now the speaker is in the MWMWW configuration.
Crossover points: 600Hz (2nd order BW) and 4000Hz (3rd order BW). Plan to crossover the 2 subs around 120Hz.
I’ve tried higher order (4th and 5th) but I can’t get a real flat curve and didn’t like the sound. I’m using a digital crossover (MiniDSP), so I’m free to change and/or EQ as much as is needed. All the drivers are connected directly to 2 Crown 1000 XLS
All the measurements are done with an UMIK-1 and verified thanks to the great REW forum help. All the .mdat files with the raw results are available
Cabinet stiffness test
Set up: 90dB, mic at 2cm from the cone, indoor, smoothed 1/48
After overlap with the drivers makers FR, I didn’t notice any big differences, except in the woofers after 200Hz where I have a slightly faster roll off, as expected.
Based on that, I assume that I don’t have any standing waves and the box is stiff enough.
Comments?
Acoustic delay
Set up: 80dB, Audissey mic at 1 meter, indoor
I’ve used the loop feature in REW for calculate the acoustic delay, switching the mic because the UMIK is an USB one and it’s not possible to get the value. Below the inverted polarity measurements (80dB, mic at 1 meter, outdoor, gated) for validate the delay
The delay input in the MiniDSP is what was measured.
This is the point where I’m less sure: the reversed spike is clear between T and M but is not exactly on the 4kHz mark, and between M and W there isn’t a clear spike, and the highest point is not on the 600Hz.
What do you think? Is it correct? I can easily modify the delay, so any recommendation here on how this FR should looks like is welcome!!
Single driver response
Set up: 80dB, mic at 1 meter, indoor, gated
Individual driver response
Frequency response
Set up: 80dB, mic at 1 meter, outdoor, gated
EQ: TW high shelf at 17k, 4dB gain, Q=1, WF low shelf at 150, 4dB gain, Q=1
Zoomed
No gate, 1/48 smooth
What do you think? Does the EQ make sense? Too much? Not too much?
