3 pairs of identical bookshelf speakers for 6.1 home theater?
twochordcool
Hello everyone!
I am new here.
And it's been a long time since I put together a stereo / home theater.
And I can now afford to do it right - somewhat.
I have noticed that a lot of Dolby Digital receivers do something like 100 watts by 6, plus subwoofer - which I think is a good thing, I guess.
Anyhow, with it having identical watts for each channel, I have thought about purchasing 3 pairs of identical bookshelf speakers - one for each location - instead of buying floorstanding left and right, a specific center channel and specific rear surround speakers.
I have 2 main questions -
Is this a good or a bad idea?
If it is OK, what speakers would you recommend that I go with if I were going to spend between $200 and $400 a pair?
Bare in mind that I enjoy all kinds of music as well as movies.
I also acknowledge that I will probably have to buy a subwoofer.
silversurfer
Having identical speakers in all locations is a very good idea. Most people can not do it due to space limitations, but if you can do it with proper placement, it is the ideal thing to do.
aarond
a friend of mine just installed his system with 6 axiom m22's and an hsu vtf-3 sub. he is using a denon 3805 for his receiver and it sounds sweet!
aaron
ps. some of us have day jobs
aarond
twochordcool said:
Hello everyone!
if you don't buy a subwoofer it will be a 6.0 not a 6.1
Buckeyefan 1
Buckeyefan 1
twochordcool said:
Hello everyone!
I am new here.
So you are budgeting $600 to $1200 for six speakers, correct? If you like all types of music, and you are set on equal sized speakers, you may want to consider bookshelves with at least a 6.5" woofer so you don't have a "hole" in your bidbass that the subwoofer cannot account for.
With home theater, it's not as much an issue. But with music, the demands on midbass will tax small bookshelves. There's even some discussion about two way speakers not being able to reproduce female voices, due to a severe lack of a midrange. It's extremely hard for bookshelves to faithfully reproduce the entire frequency range of 20-20,000. Most bookshelves lose bass around 60Hz, but even more lack the 800Hz to 1500Hz range which is pertinent to voice and symphony reproduction. An eq, or even better, a parametric eq, can make up for some of these losses. But it's still up to the drivers in a given speaker to reproduce these voices/instruments well. Speakers with two way crossovers help separate the midbass from the midrange, and the midrange from the highs.
What it boils down to is that if you have the cash for two tower speakers with two way crossovers, a dedicated center channel, and 3 or 4 bookshelves, your music and HT will be better off.
Equal wattage never goes to all speakers simultaneously unless you are using a sound parameter such as 5.1 or 7.1 stereo. Also keep in mind, during movies, your center channel does 90% of the work, while with music, your two "towers" should be doing most of the work. Your subwoofer would be next in line, and really makes up for the lack of bass in todays 8" or typically smaller woofers. They are a must for home theater, and a definite positive with music. Don't skimp on your center, your towers, or subwoofer. The surrounds should have similar tweeters for voice matching, but the size is not as pertinent.
twochordcool
Correct me if I'm wrong -
a LOT of QUALITY bookshelf speakers cover 60 to 26,000Hz -
which means that frequencies within the 800 to 1500Hz range should be accurately reproduced without any problems -
and a decent subwoofer should cover frequencies below 60Hz.
Right?
Rock&Roll Ninja
Rock&Roll Ninja
We call them "Bad speakers not worth considering". :)
Buckeyefan 1
Buckeyefan 1
Right?
Good question. It's a fallacy that speaker manufacturers state response ranges to accomodate all frequencies at efficient dB ratings. Just because a one way crossover is set at 1800Hz does not mean a 5" mid bass driver and a soft dome tweeter will reproduce 80Hz, 500Hz, 1900Hz, 3500Hz, 9000Hz, and 16,000Hz correctly and efficiently. It's extremely difficult for a full range driver to reproduce all these frequencies accurately. (Bose, for example)
Here's a perfect example. Athena's WS-100. They state a frequency response of 50-20,000 +/- 3dB. My response. Absolute B.S. Go listen to them with music. Try not to vomit in front of the salesguy.
A massive 18" HT subwoofer will produce 20Hz extremely well, but will suffer against a 12" HT subwoofer when trying to reproduce punchy 50Hz frequencies. The same is true with 8" subwoofers. They will do wonders with 65Hz, but not hold a candle to their larger brothers with frequencies under 30Hz at efficient dB levels. It's a big give and take. That's why you'll often hear the term "hole" in the sound, which is usually a bass, mid bass, or midrange issue.
