Phase Matters
Dear All,
If the subs in the same room have different rolloff frequencies, different Qts, or different order (2nd or sealed vs ported or 4th - vs ported w/high-pass circuit which could be anything from 5th to 8th order), the phase shift of a minimum phase system(which most loudspeakers are) is tied to and predicted from its frequency response. This phase shift will have significant effects on the way the subs add (As will their distance to large reflective surfaces) OR the RELATIVE distance between them to the listener. While it is a given that you will NEVER get mid and high frequency devices which are far apart to add in anything other than a completely random way (distances between them are great relative to the size of the wavelengths), at very LOW frequencies, the wavelengths can easily be greater than the entire room dimensions, so it is HERE where it is most important that phase and polarity are observed. NO ONE would question that two subs (identical) run out of phase (180 degrees apart) is a problem. Why then is it not as clear that two subs, one a sealed box with a 50hz cutoff, and the other a vented box with the same 50 hz cutoff and a second order high pass WILL NOT be in phase even when the polarity is right? The sealed box will have 90 degrees of phase shift at Fc (cutoff or -3db pt) while the vented with the 2nd order HP will have 270 degrees phase shift. (180 from the vented box, and another 90 from the second order HP filter. Just so happens, now these two units are 180 degrees out of phase AT the cutoff frequency, NOT below it....
It may be that our rooms are so awful that this effect is secondary to all the destructive interference from walls and ceiling and floor. That does not mean this advice (USE THE SAME SUBS) is not well founded. That is my two cents worth.... I HAVE measured this in fact, just one week ago.
