> Timbre - The quality of a sound related to its harmonic structure.
Agree 100% with this definition. That is why I say a speaker's timbre qualities are defined completely by its frequency response curve (the entire shape of the curve, not the freq range). If there are frequency response humps in the high freq region, the timbre of many instruments will thus be higher, etc.
> one with a horn tweeter, and one with a soft dome... could have the same frequency response and crossover settings, but would not be timber matched due to the different drivers.
If the frequency response curves were identical, I would say this hypothetical horn tweeter and hypothetical soft dome would have identical timbre qualities. However, this won't happen. Different types of tweeter have very different freq response curves.
Frequency response range, and crossover frequency, only define limits of frequency response. They don't necessarily tell anything about freq response behavior within that range.
> You want to make sure the tweeters are identical
Agree 100%.
The only things I am questioning are: 1) Is "voice-matching" the same thing as "timbre-matching"?
And 2) I still think that 2-way vs 3-way designs tend to have different frequency response curves in the mid/low frequency regions...thus I would say NOT being timbre-matched.
But like I said earlier, I think timbre-matching is not the critical issue when matching speakers for a surround system. I think identical transient response and identical phase characteristics are of the most importance. But timbre-matching would be a plus.
