2.1 for very small space
rexmcartor
I hate to be the one to come and ask a similar question to one asked thousands of times before. But I have some specific criteria, and already have some ideas. I just wanted to see where others opinions lied. In short I am looking for a budget 2.1 setup (or 2.0 but the speakers can't be to big) for under $500, preferably more like $400. I already have many headphones, speakers turntables, etc. This setup is for a very small office at work. Maybe 4'x6', being generous. I am looking for small compact desk speakers, something like Audioengine A2+. Preferably powered as to not have to buy an amp too. Then a more compact, flatter, down-firing subwoofer. Maybe only 7 or 8" max off the ground, but could be over a foot square. Would be used for music, exclusively. I do like a flat response, but also like a bit of extra bass. But the small room will take care of that. Looking to achieve at least down to 30hz.
So If you all had $300-$500 to spend on mentioned system. What would you buy?
KEW
KEW
I just picked up a pair of the JBL LSR305s, like them a lot (particularly the sale price of $180 delivered),not sure if they're small enough for your placement but the audio quality is quite good. Maybe look at this for the sub https://www.parts-express.com/dayton-audio-sub-1000l-10-100-watt-low-profile-powered-subwoofer--300-639.
Totally agree with this as probably your best option for sound quality on your budget.
However, I am not sure the speakers fit your criteria of "compact".
You mentioned the A2+, are the A5+ too large?
However, explain your situation at work a little better for us.
Can you crank it at all, or will this just be for background music?
