I went from a sub that had a -3 dB point of 28 Hz, with some output below that, to a tunable sub that went down (at - 3 dB) 18 Hz (or lower, with the other tuning options). The difference is huge. However, the difference between the subwoofers was not just the lowest end, but the level of maximum output was greater with the subwoofer that goes lower.
Since you are looking at two Hsu subwoofers, you may be looking at the VTF-1 and the VTF-2 Mk3 (there are other models that are possible). With those, the one that goes lower also can play louder. I recommend going with the better sub, assuming you can afford it and it will fit in your space. (Or, better still, go with an even better sub than you are now considering, if you can afford it and have room for it.) At worst, you would have more capability than you need, filling more space than you would like it filling. But more than likely, you would, if comparing them both in your room, much prefer the performance of the better one. Most people who have regrets about their subwoofer purchases regret not getting a better one. Very few regret having a subwoofer that is better than they think is necessary.
Additionally, when considering the maximum output of a subwoofer, typically, it will have less distortion at lower levels. Consequently, even if the maximum output and maximum extension of the lessor one were "good enough", the better one would have less distortion at that output.
