12 Volt Trigger Question
walter duque
walter duque
Is 12 V Trigger Cable a 1/8" mono mini plug?
Davemcc
Davemcc
Some people have had luck using stereo mini plugs but those wouldn't work for me. I had to find the mono plugs to use my 12v triggers.
Adam
Adam
Just in case you are asking in general, some 12V triggers don't use the minijack. My Emotiva amps use a connector that takes two bare wires.
Most with the 1/8" jack will work with that kind of cable. You can use any like this, or make them up yourself but that's often more expensive. It's a low current path. Stereo sometimes won't work because you have tip/ring connection at one end and tip/sleeve at the other, which is an open circuit.
walter duque
walter duque
Used 1/8" mono miniplug and it's working good, thanks.
