Results 1 to 7 of 7
Thread: Monoprice users need to be aware of this!!!!!!!!!!!!!!!!!!!!!!!!
  1. #1
    highfigh's Avatar
    highfigh is offline Audioholic Spartan highfigh should be listened to
    Join Date
    Sep 2008
    Location
    Milwaukee area
    Posts
    6,263
    Thanks Given
    16
    Thanks Received
    1,583
    Default Monoprice users need to be aware of this!!!!!!!!!!!!!!!!!!!!!!!!
    I don't have any problem if people use Monoprice, but....
    Those of you who do use Monoprice need to know that UL is going after them for using the UL name on their cables. This is a problem, on several levels. Being untested means that, in the event of a fire, insurance companies may decide to withhold settlement for damages. This means anyone who used these cables is likely to be sued.
    Here's a link to the UL site. A member at another forum mentioned that they were already cited for their HDMI cables.
    UL | News Item
    Never eat anything that squirts out of a machine.
  2. #2
    Irvrobinson is offline Audioholic Field Marshall Irvrobinson should be listened to
    Join Date
    Dec 2004
    Posts
    1,578
    Thanks Given
    307
    Thanks Received
    747
    Default
    Unless you're using power over Ethernet I wouldn't be so concerned about fire, I'd be more concerned about how a manufacturer so dishonest as to misuse the UL symbol might be producing a CAT-6 cable that really doesn't meet CAT-6 specs.
  3. #3
    fuzz092888's Avatar
    fuzz092888 is offline Audioholic Samurai fuzz092888 should be listened to
    Join Date
    Feb 2012
    Location
    A dream within a dream.
    Posts
    2,803
    Thanks Given
    1,176
    Thanks Received
    1,319
    Default
    Monoprice is UL certified and so are their cables. This looks to be like counterfeit cable with monoprice packaging. If you look on the UL website and type monoprice into their search box you see that monoprice is fine. Unless I'm mistaken about something, I think you need to issue a retraction. Monoprice is a BBB accredited business with an A+ rating, I would be extremely surprised if this was actually the case. If you notice on the link you provided it does not list monoprice as the retailer of this faulty cable, but some random website that looks like it has been dismantled. My guess is that they put cheaper cable in a monoprice box and were selling it.
    "You're only given a little spark of madness. You mustn't lose it."
    Philharmonic Audio
  4. The Following 3 Users Say Thank You to fuzz092888 For This Useful Post:
    darien87 (02-18-2013),majorloser (02-18-2013),zhimbo (02-18-2013)
  5. #4
    BoredSysAdmin's Avatar
    BoredSysAdmin is offline Audioholic Spartan BoredSysAdmin should be listened to
    Join Date
    Aug 2007
    Location
    NYC
    Posts
    5,604
    Thanks Given
    1,494
    Thanks Received
    1,974
    Default
    BBB rating means exactly jack, but I do have my trust in monoprice. Also imho UL Certifying CAT cable even with poe in mind is a bit like THX certified hdmi ... just saying...
    CAT5/6 are certifications by themselves. If cable is not capable of cat6 speeds then we have a serious problem
    TV: TC-P55ST30 , AVR: TX-SR805. The Speaker Company 2x TST2, TC2, 2x TSB , Premier Acoustic PA-120 Sub, Netgear NeoTV 550, Harmony 880 URC RFS200, PC->Toslink-> Audioengine D1->JBL LSR2325P
    When you're arguing with an idiot, make sure the person you are speaking to isn't doing the same thing.
  6. #5
    fuzz092888's Avatar
    Join Date
    Feb 2012
    Location
    Posts
    2,803
    Thanks Given
    1,176
    Thanks Received
    1,319
    Quote Originally Posted by BoredSysAdmin View Post
    I wouldn't go that far. It doesn't mean a whole lot, but at least means they respond and resolve any issue reported about them. Besides, simply checking the UL website would have laid all this to rest.
    Philharmonic Audio
  7. #6
    j_garcia's Avatar
    j_garcia is offline Seriously, I have no life. j_garcia should be listened to
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,285
    Thanks Given
    1,664
    Thanks Received
    3,805
    Default
    THX cert on cables is useless. UL rating however is entirely different - it has to do with them passing manufacturing specifications and any applicable safety requirements (fire resistance for example), not whatever "performance" ratings someone decided to make up.
    HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
    System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
    Are you sure which side of the glass you are on?
  8. #7
    mtrycrafts's Avatar
    mtrycrafts is offline Audioholic Overlord mtrycrafts should be listened to
    Join Date
    Aug 2004
    Posts
    14,777
    Thanks Given
    142
    Thanks Received
    1,090
    Default
    Quote Originally Posted by j_garcia View Post
    Yep, that is my understanding as well what UL tests for safety, not tech specs.
    Update from that link:
    Hazard: This communications cable is missing required flame retardant elements. This may cause an increased risk of fire.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
