Results 1 to 5 of 5
Thread: Cover leads on outdoor speakers
  1. #1
    mirx is offline Audiophyte mirx is a forum member in good standing
    Join Date
    Dec 2012
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Default Cover leads on outdoor speakers
    Hi,
    TL;DR: What's the best way to cover outdoor speaker ends for a snowy Canadian winter?
    The story:
    I installed a pair of Yamaha ns-aw392 all weather speakers on my back deck this summer. I'm going to take them down for the cold snowy Canadian winter before any snow actually flies. My generally thought is the speakers will last a few years longer if I treat them better. I ran good high quality rubberized cable outside, and terminated one speaker with banana clips, and screwed the wire directly on to the screw terminates on the 2nd speaker. The banana clips were forcing the speaker to be angled up higher then I wanted them, not allowing for a snug fit against the house. When I take the speakers down, I'm wondering, what's the best way to cover outdoor speaker wire ends? Tuck them under the siding? Wrap them in a plastic? Duck tape them? I'm not sure what's the best way to protect the wire ends for next spring.
    Thanks for any tips.
  2. #2
    macddmac is online now Full Audioholic macddmac should be listened to
    Join Date
    Mar 2012
    Location
    Colorado
    Posts
    383
    Thanks Given
    265
    Thanks Received
    138
    Default
    I leave my Polk's out year round here in Colorado- damn things still work great after 11 winters :0
    They're under eaves so there's not that much wear and tear on them from snow and rain though.. Ymmv.
    Cheers, Mac
  3. #3
    slipperybidness's Avatar
    slipperybidness is offline Audioholic General slipperybidness should be listened to
    Join Date
    Jul 2011
    Posts
    1,264
    Thanks Given
    28
    Thanks Received
    292
    Default
    Quote Originally Posted by mirx View Post
    Hi,
    The story:
    Personally, I would probably put a piece of heat shrink over exposed wire ends and shrink it down. Re-insulate it like that for the winter and remove for re-install after.
    Probably, a few pieces of electrical tape would do the same thing, but it might leave some adhesive residue.
  4. #4
    Rickster71's Avatar
    Rickster71 is offline Audioholic Spartan Rickster71 should be listened to
    Join Date
    Jan 2006
    Location
    N.J.
    Posts
    5,518
    Thanks Given
    3,479
    Thanks Received
    3,218
    Default
    Good idea taking the speakers in, I do the same thing.
    I'd recommend not using the banana plugs at all. It's just an added connection and the possibility for added resistance as things oxidize.
    Try these wire nuts filled with Noalox for winter: IDEAL INDUSTRIES, INC. - Twister AL/CU Twist-on Wire Connector
    The coating they will leave on the wire will also protect the connection from oxidation while hooked to the speakers too.
    There's what people want to hear.
    There's what they want to believe.
    Then there's the truth.
  5. The Following 2 Users Say Thank You to Rickster71 For This Useful Post:
    Alex2507 (12-08-2012),GO-NAD! (12-10-2012)
  6. #5
    GO-NAD!'s Avatar
    GO-NAD! is offline Audioholic Ninja GO-NAD! should be listened to
    Join Date
    Apr 2009
    Location
    Nova Scotia, Canada
    Posts
    3,067
    Thanks Given
    3,699
    Thanks Received
    1,428
    Default
    Quote Originally Posted by Rickster71 View Post
    That's a great idea, Rick. I've just been wrapping the ends of my wires with electrical tape and in the spring, run a bit of sandpaper over them to remove oxidation. I haven't had any problems, but I like those connectors.
  7. The Following User Says Thank You to GO-NAD! For This Useful Post:
    Rickster71 (12-13-2012)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
