Results 1 to 9 of 9
Thread: NetGear Powerline AV500 Adapter Kit Video Review
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow NetGear Powerline AV500 Adapter Kit Video Review
    It seems these days everything requires an Internet connection - at least for anything having to do with home theater. So what do you do if you don't have your house wired for Internet? What if you want to stream movies and your wireless connection can't quite cut it? Well the HomePlug Powerline Alliance got together a ton of companies and created a standard for networking over powerlines. You can use your home's existing electrical system - the regular power outlets you have all over the place - and transmit networked audio, video and data. And it's not expensive to do. Devices like Netgear's Powerline AV500 Kit are set to revolutionize the way we connect our homes and our gear. You should check it out, because our testing shows that it beats wireless hands-down - it just may forever change the way you look at networking.
    Discuss "NetGear Powerline AV500 Adapter Kit Video Review" here. Read the article.
  2. #2
    Sugarbear's Avatar
    Sugarbear is online now Audioholic Intern Sugarbear is gaining some recognition
    Join Date
    Jan 2010
    Posts
    49
    Thanks Given
    44
    Thanks Received
    10
    Default
    I have a set of these and they work great.
    Be careful, though. - AirPlay doesn't work over them.
    I'm waiting for NetGear to issue a firmware update to address.
  3. #3
    Lulimet's Avatar
    Lulimet is offline Junior Audioholic Lulimet is gaining some recognition
    Join Date
    Apr 2011
    Location
    Perkasie, PA
    Posts
    83
    Thanks Given
    7
    Thanks Received
    19
    Default
    Some models won't work if they aren't in the same circuit.
    In metal I trust
  4. #4
    Cruise Missile's Avatar
    Cruise Missile is offline Full Audioholic Cruise Missile should be listened to
    Join Date
    Mar 2007
    Location
    Dayton, Oh.
    Posts
    379
    Thanks Given
    207
    Thanks Received
    132
    Default
    This is now on my short list of things to get. I've been running a wireless bridge to get internet to the theater.
    Needless to say, the performance has been sub-par. An in-home increase of network speed would prevent me from having to put the server in the theater (loud). Thanks guys!
  5. #5
    GoFastr's Avatar
    GoFastr is offline Full Audioholic GoFastr has a small fan club
    Join Date
    Jun 2011
    Location
    Paradise
    Posts
    268
    Thanks Given
    55
    Thanks Received
    66
    Default
    Maybe this model is better but don't get your hopes up too high.
    I bought the NETGEAR Home Theater Internet Connection Kit last year and have stopped using it. My AVR is about 25 feet from my DSL modem but with a doorway between them and concrete block walls on the outside. No way to run wires in the walls. I tried to use the NetGear product by plugging it into the electrical wall outlet by the DSL modem and the receiver in the electrical wall outlet by the AVR. I did get a connection but it was still VERY slow. Remember the days of green screens and graphics/text that you could actually watch line by line as the page loaded! It took forever to load my collection of picture albums and music folders onto the TV screen so I gave up and just ran a cable on the floor directly between them until I finally got someone over to go up in the roof and run the cable right.
    Good luck with it!
    Denon AVR-3311CI, Emotiva XPA-5 amp, Klipsch RF-7 classics fronts, Klipsch RC-64II center, Klipsch KS-7502-THX surrounds, BIC PL-200 sub, Mitsubishi 73 inch DLP TV, Denon DVD-2500BTCI Blu-Ray player, Klipsch M40 headphones, MonoPrice & Emotiva cables, Logitech Harmony 1100 remote, Wii, xBox360 Elite, iPOD, LAN, Zone 2=pair of Klipsch AW-650 outside - looking for a deal on SVS PC-Ultra-13 or FW 15.2.
  6. #6
    scott911 is offline Full Audioholic scott911 has a small fan club
    Join Date
    Nov 2007
    Posts
    258
    Thanks Given
    65
    Thanks Received
    27
    Default
    consider running a real cat 5e or 6 cable... unless you live in an apartment, etc... find a buddy with the basic know how, get a six pack, and go to it!
    A wired connection will be able to handle huge amounts of data compared to wireless, it doesn't need athentication, rebooting, power, handshaking, passwords, etc...
    I do use wireless for alot of stuff where I can't be bothered... like wii in the kid's room.
    But for the ever growing demands of Home theater and straming, it was worth it to get a solid connection.
    Although not ideal, remeber your can run ourside house - especially if you have siding, you can snake your cable under a run of siding to get between floors, etc...
  7. #7
    GoFastr's Avatar
    Join Date
    Jun 2011
    Location
    Paradise
    Posts
    268
    Thanks Given
    55
    Thanks Received
    66
    Default
    Quote Originally Posted by GoFastr View Post
    Good luck with it!
    I just want to point out that some of my troubles may have to do with the electrical outlets I chose to use. My kitchen outlet where the DSL modem was and my family room outlet where the AVR was are definately not on the same circuit and most likely the home run back to the panel box way on the opposite side of the house is a long trek.
    I may give the device another try by trying to find outlets on the same circuit and see if response times improve. They must work for some people otherwise they wouldn't be selling as many as they have been.
  8. #8
    Opteron1944 is offline Audiophyte Opteron1944 is a forum member in good standing
    Join Date
    Apr 2009
    Posts
    2
    Thanks Given
    0
    Thanks Received
    0
    Default Netgear Network over AC power lines
    I have been using an earlier version of this unit for several years with great success in a house with several 50 year-old wired circuits. There is no need for the units to be on the same circuit.
    Indeed, the only physical issue is that the units must be plugged directly into the wall - no power strips or other filters of any kind are permitted. This is because the filters in most power strips and conditioners will block the frequencies these units depend on.
    If there is a noticeable drop in speed or failure to connect, it can be indicative of a incompatible configuration setting for the NIC or software firewall.
    Should FIOS ever make its way to my home, I'll quickly upgrade to these latest units.
  9. #9
    Fedaykin is offline Audiophyte Fedaykin is a forum member in good standing
    Join Date
    Sep 2011
    Posts
    8
    Thanks Given
    0
    Thanks Received
    0
    Default
    I have the 200Mbps version of these. Tests show I get about 180Mbps actual, which is pretty good. I'll be upgrading to the 500's soon. So much better than wireless -- but it's rather hit or miss depending on the quality of the wiring in your house.
    Buy local so you can easily return (this is why I only have the 200 -- no local dealers had the 500)
    Just remember when you test the speed that it's actually possible that your computer, blueray player, etc. is the bottleneck not the connection itself. A lot of gear still only have 100mbps adapters and once you get around 500mbps hard drives in laptops and older computers can't keep up with that speed.
    The best way to test your speed is with network benchmarking software and two computers with a 1Gbps capability!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
