Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Connecting powered sub to power conditioner
  1. #1
    Soundman's Avatar
    Soundman is offline Audioholic General Soundman is considered a mentor
    Join Date
    Jun 2007
    Location
    Dortches, NC
    Posts
    1,436
    Thanks Given
    106
    Thanks Received
    143
    Default Connecting powered sub to power conditioner
    Hey Guys,
    Any ideas on how to connect my powered sub to my power conditioner/surge protector?? My sub is currently too far away to plug it in. Any ideas?
    HT
    Pre/pro- Emotiva LMC-1/LPA-1 Sources- Panasonic DMP-BDT220, Nintendo Wii, PS3 80g with Samsung M6 Series HM320JI 320GB HDD Display- Mitsubishi WD-65736 Speakers-Rocket RS850 Signature (mains), Rocket RSC 200 Signature (center), Rocket RS450's (surrounds) Sub- PB-13 Ultra Other- APC 350, Newpoint 204220 Wires/Interconnects- Monoprice
  2. #2
    markw's Avatar
    markw is online now Audioholic Spartan markw should be listened to
    Join Date
    Nov 2003
    Location
    New Joisey
    Posts
    7,493
    Thanks Given
    847
    Thanks Received
    1,912
    Default
    First off, I don't know the power rating of your power conditionsr or your sub but generally high-powered decices (power amps,ubs, etc...)should be plugged directly into the wall.
    As to your original question, Mr Obvious says you should either move something or get a ginormous extention cord.
    "Knowledge is knowing that a tomato is a fruit; wisdom is knowing not to put it in a fruit salad" - Anonymous
    Some of my systems: http://cgi.audioasylum.com/systems/1606.html
  3. The Following User Says Thank You to markw For This Useful Post:
    Soundman (11-07-2009)
  4. #3
    Rickster71's Avatar
    Rickster71 is offline Audioholic Spartan Rickster71 should be listened to
    Join Date
    Jan 2006
    Location
    N.J.
    Posts
    5,516
    Thanks Given
    3,478
    Thanks Received
    3,212
    Default
    If you have all your other equipment connected to your surge protector, I wouldn't add the sub to it. (as Mark mentioned)
    Getting a small unit to go near your sub would work; perhaps a UPS.
    I solved the problem with installing 'whole house' surge protection on both of my electrical panels. Also added Hubbell surge protection outlets.
    Another thing I do, is faithfully unplug my sub after every use. There is no better protection than unplugging.
    It works out to being plugged it for around 2 - 4 hours a week
  5. The Following 2 Users Say Thank You to Rickster71 For This Useful Post:
    renegade87 (02-23-2010),Soundman (11-07-2009)
  6. #4
    Adam's Avatar
    Adam is online now Audioholic Jedi Adam should be listened to
    Join Date
    Jul 2006
    Location
    Tucson, Arizona
    Posts
    26,516
    Thanks Given
    7,573
    Thanks Received
    9,125
    Default
    I have my sub (SVS PC13-Ultra) plugged into my Belkin power center, and I've never noticed any issues. It has two amps, a TV, a receiver, two disc players, a computer, and my sub plugged into it.
    As for getting the power cord to reach, you might consider just buying a different power cord if your sub has a detachable cord. Monoprice sells nice power cords for not much money. You can get them at other places, too.
    Mains and Surrounds: NHT 1.5s, Center: NHT AudioCenter-1, Subs: SVS PC13-Ultra, SB13-Ultra, Receiver: Pioneer Elite VSX-23, Amps: Emotiva RPA-1, POS-1, Display: Panasonic TC-P50G10
  7. The Following 2 Users Say Thank You to Adam For This Useful Post:
    GO-NAD! (12-23-2009),Soundman (11-07-2009)
  8. #5
    Soundman's Avatar
    Join Date
    Jun 2007
    Location
    Dortches, NC
    Posts
    1,436
    Thanks Given
    106
    Thanks Received
    143
    Default
    Quote Originally Posted by Rickster71 View Post
    Thanks. That's kinda what I'm doing right now. I have the sub plugged into an inexpensive power strip.
    HT
  9. #6
    Adam's Avatar
    Join Date
    Jul 2006
    Location
    Tucson, Arizona
    Posts
    26,516
    Thanks Given
    7,573
    Thanks Received
    9,125
    Default
    Quote Originally Posted by Adam View Post
    Oops. Should have just looked at your signature.
  10. #7
    Soundman's Avatar
    Join Date
    Jun 2007
    Location
    Dortches, NC
    Posts
    1,436
    Thanks Given
    106
    Thanks Received
    143
    Default
    Nice idea! I'm using the PB-13 Ultra, so yes, it does have a detachable power cord. I just didn't think of doing that.
    HT
  11. #8
    Soundman's Avatar
    Join Date
    Jun 2007
    Location
    Dortches, NC
    Posts
    1,436
    Thanks Given
    106
    Thanks Received
    143
    Default
    Hey, it never hurts to ask.
    HT
  12. The Following User Says Thank You to Soundman For This Useful Post:
    Adam (11-07-2009)
  13. #9
    Rickster71's Avatar
    Join Date
    Jan 2006
    Location
    N.J.
    Posts
    5,516
    Thanks Given
    3,478
    Thanks Received
    3,212
    Default
    Quote Originally Posted by Soundman View Post
    The only problem I see there, is you'll be running your sub input wire within close proximity and parallel with the power cord.
  14. #10
    Adam's Avatar
    Join Date
    Jul 2006
    Location
    Tucson, Arizona
    Posts
    26,516
    Thanks Given
    7,573
    Thanks Received
    9,125
    Default
    Just a note - I do that, and I haven't noticed any hums or other audible issues.
  15. The Following 2 Users Say Thank You to Adam For This Useful Post:
    GO-NAD! (12-23-2009),MidnightSensi (11-07-2009)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
