Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: HDMI 1.4 and Through the Ages
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow HDMI 1.4 and Through the Ages
    Key Digital had an interesting newsletter that got sent out this week. In it they had a table which went through the various iterations of HDMI, from version 1.0 through the newest 1.4. We thought it was a good chart, though we disagreed (slightly) with some of their assessments on the importance of each of the versions. As I hinted at in my article on The Twelve Biggest Industry Mistakes of the Digital Age I believe that HDMI is really more of a stop-gap interface whereas it could have been a new standard. Instead, we have a largely "stupid" new cable system that merely carries data. HDMI 1.4 does little to change this reality.
    Discuss "HDMI 1.4 and Through the Ages" here. Read the article.
  2. The Following User Says Thank You to admin For This Useful Post:
    AVRat (09-06-2009)
  3. #2
    davidtwotrees's Avatar
    davidtwotrees is offline Audioholic General davidtwotrees should be listened to
    Join Date
    Oct 2006
    Location
    Wheaton, IL suburb of Chicago
    Posts
    1,157
    Thanks Given
    183
    Thanks Received
    191
    Default
    Good article, Clint. It was interesting to note that v1.0 hdmi did everything 99% of consumers need to do in their home systems. The progression of versions in hdmi is really a snapshot of the consumer electronics industry, imho. They are making everything WAY too complicated for the end user.
    Quad 12L Active,Aperion 8A Sub, LexiconDC1,Samsung BDP2550,Escient SE80,Panasonic42PX,ParasoundHCA1000 for zone 2
  4. #3
    BoredSysAdmin's Avatar
    BoredSysAdmin is offline Audioholic Spartan BoredSysAdmin should be listened to
    Join Date
    Aug 2007
    Location
    NYC
    Posts
    5,606
    Thanks Given
    1,496
    Thanks Received
    1,974
    Default
    I'm not a grammar Nazi, but Clint - your spellcheck missed this one:
    "It is not clear if HDMI will comp7ete with DVI or Display Port in this market"
    TV: TC-P55ST30 , AVR: TX-SR805. The Speaker Company 2x TST2, TC2, 2x TSB , Premier Acoustic PA-120 Sub, Netgear NeoTV 550, Harmony 880 URC RFS200, PC->Toslink-> Audioengine D1->JBL LSR2325P
    When you're arguing with an idiot, make sure the person you are speaking to isn't doing the same thing.
  5. #4
    Biggiesized's Avatar
    Biggiesized is offline Senior Audioholic Biggiesized is looking for a job at AH
    Join Date
    Feb 2008
    Location
    Pittsburgh, PA
    Posts
    510
    Thanks Given
    385
    Thanks Received
    63
    Default
    It will take 4 times the encoded bandwidth data rate to transmit 4Kx2K/24 compare to 1080p/24. That means to transmit one 4Kx2K it will take the space of four current HDTV channels or 24 current SDTV channels.
    Where is your evidence for this? Sure, the frame size is four times as large, but who says the encoded stream must be four times as large? Ben Waggoner believes 4K/24p can be done at around 60 Mb/s with the latest codecs. Let's not forget to mention that future codec design will migrate towards wavelets, which can be way more efficient than DCT.
  6. #5
    dgreenstein55 is offline Audiophyte dgreenstein55 is a forum member in good standing
    Join Date
    May 2008
    Posts
    4
    Thanks Given
    0
    Thanks Received
    2
    Default Encoding = Compression
    "Where is your evidence for this? Sure, the frame size is four times as large, but who says the encoded stream must be four times as large? Ben Waggoner believes 4K/24p can be done at around 60 Mb/s with the latest codecs. Let's not forget to mention that future codec design will migrate towards wavelets, which can be way more efficient than DCT."
    Biggie - The point of stating that 4K resolution will take 4 times the amount of data space is that using the current standards of encoding/compression MPEG4, it would take 4 times the bandwidth to display 4 times the picture! All we need is more compression schemes to further disrupt the video we currently look at, 1080p while fantastic is always compressed and for anyone who has ever seen a clip of completely uncompressed video, like myself, you will learn that uncompressed 1080p is far more breathtaking that a compressed 4K stream.
    Ultimately HDMI will not have enough bandwidth to carry what will become available in the future of video. DVI has always been the better solution, for one it LOCKS and two it is Video only, and any experienced Home Integrator knows that a high end Disc player will always do a better job of audio decoding and sending it out via analog so it stands to reason that a medium to transfer data should always serve one purpose and in the case of video we need to quit cramming audio and control and so on down the pipe!
  7. #6
    Anagoge is offline Junior Audioholic Anagoge is a forum member in good standing
    Join Date
    Oct 2006
    Posts
    65
    Thanks Given
    0
    Thanks Received
    0
    Default
    I think the description of the Audio Return Channel misses one big use case that has immediate benefit for me. Right now, I have to run two cables between my TV and receiver. One is the normal HDMI for input of DVD type signals. The other is the optical audio from the TV to the receiver so the receiver can play the audio for over-the-air (OTA/"antenna") HDTV signals. The Audio Return Channel would remove the need for this second optical cable and allow the TV's audio to travel to the receiver on the same cable that supplies the DVD input to the TV. I know many people ignore them, but OTA HD local stations are less compressed than the cable/satellite equivalents here.
  8. #7
    buzzy is offline Audioholic Intern buzzy is a forum member in good standing
    Join Date
    Jan 2006
    Posts
    39
    Thanks Given
    3
    Thanks Received
    2
    Default
    The industry viewed HDMI first and foremost (by far) as a vehicle to implement copy protection. That everything else (like ease of use, reliability, and capabilities, and long term migration path) was an afterthought, is a natural result of that mindset.
    And this is the same kind of thinking that led to the music industry imploding. Rather than focus on customer needs, they kept trying to bend consumers over to meet their needs.
    When they start thinking about consumer needs and experience first, they may be able to turn the tide in their favor. Otherwise, people have other things to do.
  9. #8
    KurtBJC is offline Audioholic KurtBJC is looking for a job at AH
    Join Date
    May 2007
    Posts
    112
    Thanks Given
    4
    Thanks Received
    193
    Default
    Quote Originally Posted by Biggiesized View Post
    HDMI isn't sent compressed. If you've got four times as many pixels to send, it takes four times as much bandwidth.
    Kurt
    Blue Jeans Cable
  10. #9
    Join Date
    Feb 2008
    Location
    Pittsburgh, PA
    Posts
    510
    Thanks Given
    385
    Thanks Received
    63
    Default
    Okay, there seems to be a misunderstanding between us.
    Are you stating it takes 4 times the bandwidth to deliver OVER HDMI? Or are you stating it takes 4 times the encoded bandwidth over a cable system?
    I'm arguing the latter.
  11. #10
    Join Date
    Feb 2008
    Location
    Pittsburgh, PA
    Posts
    510
    Thanks Given
    385
    Thanks Received
    63
    Default
    Quote Originally Posted by dgreenstein55 View Post
    Do you have any 4K source material? Would you like to run a test between 2160p50 and 1080p50? We can set the test parameters as follows:
    1080p50 content is allowed a peak bitrate of 40 Mb/s.
    2160p50 content is allowed a peak bitrate of 80 Mb/s. (that's only DOUBLE the encoded bit rate)
    Are you saying that this cannot be done or that it requires a bit rate of 160 Mb/s (since 2160p is four times the frame size)?
    If you're game, download the Crowd Run source files from Xiph:
    http://media.xiph.org/svt/2160p50_Cg...ter_SVTdec05_/
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
