admin should be listened to
You may not spend hours and hours thinking of new ways to run long lengths of USB cable, but if you need it to occur, then it suddenly becomes the focus of your thoughts. USB has a practical maximum length of just 5 meters. If you're running an equipment room, remotely-located home theater PC, or even just a really long Guitar Hero III cable, then a USB Superbooster is probably something you should investigate.
Discuss "USB Superbooster Cat5e Extenders" here. Read the article.
