Results 1 to 3 of 3
Thread: Planet Waves DIY Home Theater Cable Making Kits
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Planet Waves DIY Home Theater Cable Making Kits
    The Planet Waves DIY Home Theater Kit proved to be a versatile product for the end user and custom installer alike. It’s probably the easiest self terminating system I have come across and the fact that you can pretty much utilize any conceivable analog termination on the market with a simple twist on connector and fastening screw is something every home theater aficionado and cable installer should have in their bag of tricks. While it didn’t score very high on value, it’s a snake oil free product that even your grandma could use. If you’re looking to customize/shorten your cable lengths while clearing out the cable spaghetti in the back of your rack, this is an excellent solution to consider.
    Discuss "Planet Waves DIY Home Theater Cable Making Kits" here. Read the article.
  2. #2
    tn001d's Avatar
    tn001d is offline Senior Audioholic tn001d has a small fan club
    Join Date
    Apr 2007
    Location
    Cleveland , Ohio
    Posts
    562
    Thanks Given
    27
    Thanks Received
    42
    Default
    My response is: Bluejeanscables.com
    HD Theater: Mitsubishi WD-65908 (Calibrated), Denon DVD-3800BDCI, Toshiba HD-XA2, Denon AVR-2807, Scientific Atlanta 8300 HD-DVR, Sony SCD-2000ES, Paradigm 6.1 System, SVS PB10-ISD, Monster Signature HTS7000MKII, Monster HTS-5100MKII
    Digital Theater : Sony 40inch 1080P 120Hz LCD TV, Denon AVR-2809CI, Paradigm 5.1 System, SVS PB10-NSD, Sony BDP-S550, Toshiba HD-A35, Scientific Atlanta 8300 HD-DVR, Sony 5 Disc CD, Sony Dual Cassette Deck, Teac Dual CD Recorder, Monster HTS-3600MKII
  3. #3
    gene's Avatar
    gene is online now Supreme Audioholics Overlord gene should be listened to
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,819
    Thanks Given
    819
    Thanks Received
    2,401
    Default
    While I am huge fan of Bluejeans cable, the average end user cannot self terminate their own cables and you need expensive crimping tools and know how to do the job right with 1694 and canare connectors.
    Gene DellaSala
    President, Audioholics
    Pursuing the truth in audio & video...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
