Page 1 of 7 123 ... LastLast
Results 1 to 10 of 70
Thread: Speaker Cable Gauge (AWG) Guidelines
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Speaker Cable Gauge (AWG) Guidelines
    Lately we’ve been getting hit with the common question “what speaker wire gauge should I use”? More often than not, we’ve seen Audiophiles choose a higher gauge esoteric wire over a lower gauge generic zip cord cable simply because they were sold some marketing nonsense that their magic cables would improve your systems mojo. This guide cuts through the nonsense and gives some solid recommendations on selecting speaker wire gauge based on the length and impedance of your loudspeakers.
    Discuss "Speaker Cable Gauge (AWG) Guidelines" here. Read the article.
  2. #2
    gliz's Avatar
    gliz is offline Full Audioholic gliz has a small fan club
    Join Date
    Oct 2007
    Location
    dallas
    Posts
    284
    Thanks Given
    57
    Thanks Received
    28
    Default
    excelant information, gonna print out that chart and keep it handy
    "A government big enough to give you everything you want is a government big enough to take from you everything you have." -- Gerald Rudolph Ford
  3. #3
    Haoleb's Avatar
    Haoleb is offline Audioholic General Haoleb should be listened to
    Join Date
    Jul 2006
    Location
    Maine
    Posts
    1,448
    Thanks Given
    27
    Thanks Received
    327
    Default
    Looks like im good to go with my "DIY" speaker cables consisting of four 8 gauge conductors. Two for positive two for negative. I even terminated them in high amerage lugs Next to them is my Audioquest Type 4 that i have on my computer system. I used to use the AQ on my main rig but I like the bigger look of black hoses along the floor, Plus looking at those graphs Im sure it makes a difference with my damping factor
  4. #4
    AUtiger's Avatar
    AUtiger is offline Junior Audioholic AUtiger is gaining some recognition
    Join Date
    Aug 2006
    Location
    Waycross, GA
    Posts
    83
    Thanks Given
    13
    Thanks Received
    4
    Default Bi-amp - diff guage wire?
    Per Lonnie's suggestion (@ Emotiva) I'm going to bi-amp my Energy speakers (running 5.1 & have IPS-1 amp, so 2 unused channels), My question is: I currently am running 12g wire from IPS-1 to fronts ,approx 8ft. I don't have anymore 12g but do have some old Monster that was given to me or I have some 18g zip wire. I thought I would leave the 12g to the tweeters and run the heavier monster to the woofers. Would it matter not matching the guage? Thx
    WAARRRR DAMN EAGLE!!!!!!
    Emotiva IPS-1 & LMC-1, Mains Energy RC10's & LCR, Surr. Proficient C850's, Velo SPL1200R, Toshiba SD 6980, Panny TC P54G25
  5. #5
    gene's Avatar
    gene is online now Supreme Audioholics Overlord gene should be listened to
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,818
    Thanks Given
    819
    Thanks Received
    2,401
    Default
    Don't use 18AWG speaker cable. You have all of this nice equipment, why skimp on a few bucks? Get some decent 10 or 12AWG cables and you will be good to go.
    Gene DellaSala
    President, Audioholics
    Pursuing the truth in audio & video...
  6. #6
    AUtiger's Avatar
    Join Date
    Aug 2006
    Location
    Waycross, GA
    Posts
    83
    Thanks Given
    13
    Thanks Received
    4
    Default
    sorry din't clarify, the monster is 8g or10g, (the 18g zip was some other wire an installer used THAT I REMOVED), so I'm good with the monster 8g-10 g? Thx
  7. #7
    gene's Avatar
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,818
    Thanks Given
    819
    Thanks Received
    2,401
    Default
    The monster is likely 12AWG so it will work just fine. You don't have to match wire gauge, just use 12AWG or less and you will be ok.
    Gene DellaSala
  8. The Following User Says Thank You to gene For This Useful Post:
    AUtiger (01-23-2008)
  9. #8
    Tuddy is offline Enthusiast Tuddy is a forum member in good standing
    Join Date
    Dec 2007
    Posts
    10
    Thanks Given
    0
    Thanks Received
    0
    Default Newbie ?
    Gene,
    Thanks for the article and the timing could not have been better
    as I almost bought some "snake oil" speaker cable for $400 bucks
    After reading your article and some actual reviews that included measurement
    analysis of the MI* cable I almost bought I have decided to get the 6 foot Sonicwave 10 AWG.
    It seems the shorter the run the less AWG needed. True?
    Do I need 10 AWG with 6 foot runs? it won't damage the speakers, will it?
    I have read the shorter and thicker the speaker cable the better
    and I want some quality for the B&W 804S's.
    Appreciate any feedback folks.
  10. #9
    ro7939 is offline Audiophyte ro7939 is a forum member in good standing
    Join Date
    Nov 2008
    Posts
    2
    Thanks Given
    0
    Thanks Received
    0
    Default
    Your wire chart displaying insertion loss per distance @ 8-Ohms is ultra sweetalicious! Thanks!
    Flat speaker cable is going under pre-laid carpet on slab floor; critical this be done only once.
    This is a top-level music system w/ costly, meticulously chosen French monitors. Question applies only to the critical front speakers. Owner is a musician & very picky.
    The speakers are NOMINAL 8-Ohm but dip to 5.4-Ohms, briefly at 80 Hz & from about 100-400 Hz. Source is 110W RMS amp rated only down to 8-Ohms, indicating minimum current reserves. Balancing the amp's 8-Ohm minimum rating is the fact that the speaker has a sum total one 6.5" bass/mid & is actively HPX'd @ 80 Hz.
    Being particularly picky (some might say anal), if the AWG is matched to the speaker's MINIMUM impedance, the 25'/8-Ohm NOMINAL cable length converts to about 40' @ 5.5-Ohms on the chart.
    The chart line indicates a minimum AWG of 13.5 but the largest flat wire seen so far is AWG15. Should I double the wire runs? From another chart is looks like doubling the AWG lowers the AWG (thicker) by a quantity of three, in other words 2x AWG15 = AWG12. Is that correct? If so, I may employ 2x AWG16 for an equivalent AW13.
    Many thanks in advance.
    Jimbo
  11. #10
    ParadigmDawg's Avatar
    ParadigmDawg is offline Audioholic Warlord ParadigmDawg should be listened to
    Join Date
    Nov 2006
    Location
    Hiding from Alex
    Posts
    9,309
    Thanks Given
    2,424
    Thanks Received
    2,630
    Default
    This is still my favorite, it is very nice and not too expensive.
    I also like what Haoleb made.
    A bunch of Paradigm stuff, a big sub, a few amps and 3 plasma's...Panny of course...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
