Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Ask Dr. A! Does Speaker Cable Gauge Matter?
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Ask Dr. A! Does Speaker Cable Gauge Matter?
    It's been a while since Dr. A answered a reader question so we pulled him away from his 4 month karaoke binge and tossed a new question at him. Seems like Dr. A has an addictive personality so we'll need to keep him a bit more occupied in the future for his own good. This question, from philophobos via our forums, has to do with speaker cable gauge, but we expanded it a bit in our answer to address some other related situations.
    Discuss "Ask Dr. A! Does Speaker Cable Gauge Matter?" here. Read the article.
  2. The Following User Says Thank You to admin For This Useful Post:
    majorloser (11-30-2007)
  3. #2
    ibgarrett is offline Audiophyte ibgarrett is a forum member in good standing
    Join Date
    Nov 2007
    Posts
    3
    Thanks Given
    0
    Thanks Received
    0
    Default So how would Mini-coax compare?
    I'm in the process of finishing my basement and I'm putting in a home theater system as part of the process. I've decided to try using some mini-coax cable because of the size and easy of use with the connectors. (For the cable type just send me an email - I haven't posted enough yet, so I can't include the link) I also like it because it's shielded.
    How does that compare to speaker wire?
    Brian
  4. #3
    gene's Avatar
    gene is offline Supreme Audioholics Overlord gene should be listened to
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,818
    Thanks Given
    819
    Thanks Received
    2,401
    Default
    You don't need shielding for speaker cables in 99% of installs. Don't forget a speaker is a low impedance device so you won't get much pickup at all from outside sources.
    Find out the gauge on the mini COAX but I suspect it will be 18AWG or higher thus I'd recommend either cross connecting 2 COAXs, or using conventional 4/4 speaker wire paralled to yield an effective gauge of 11AWG.
    Gene DellaSala
    President, Audioholics
    Pursuing the truth in audio & video...
  5. #4
    yettitheman's Avatar
    yettitheman is offline Audioholic General yettitheman is quite helpful
    Join Date
    Dec 2006
    Location
    I live in a pizza box
    Posts
    1,088
    Thanks Given
    237
    Thanks Received
    128
    Default
    Yes and no. I reference the article at hand, as longer distances benefit marginally from increased wire gauge.
    I'll say this; inside your typical HTR, the wires connecting the speaker terminals from the amplifier circuit board are usually MUCH smaller than the cable you are using to run to the speakers from your HTR.
    I am the Yamaha guy
    "rsahposdey sucks."
    B&W DM602 S3 / Yamaha DSP-A1000 / Yamaha CDV-1200K Laserdisc Player / Yamaha CDV-1700 Laserdisc Player / Sony SCD-CE595 SA-CD player / Yamaha KX-W952 Tape Deck / Superscope TD-48 Quadraphonic 8-Track Player / JVC QL-F4 Turntable / Yamaha TX-950 Tuner / 40GB PS3 (soon to be 160 GB ) / Onkyo DX-1500 CD Player converted into HTPC
    Mitsubishi Medallion WD-57732 DLP TV
    Samsung TX3071WHF HD-Monitor
  6. #5
    gene's Avatar
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,818
    Thanks Given
    819
    Thanks Received
    2,401
    Default
    Yes and those are extremely short distances and anything with power connections still usually have 14AWG or soldered on to pcb board with very thick traces. The small wires are usually connection digital circuits and pass extremely low current signals.
    Gene DellaSala
  7. #6
    kelsci is offline Audiophyte kelsci is a forum member in good standing
    Join Date
    Nov 2006
    Location
    so fla
    Posts
    2
    Thanks Given
    0
    Thanks Received
    0
    Default
    Hi; I conducted passive surround sound experiments during the 80s and 90s with four and five channel dynaquad ciruits. My use was with 18 gauge wire. One time, I wired up the circuit with 16 gauge wire. The soundfield collapsed into the middle of the room as one big monophonic muddle. So this circuit told me something of the importance of 18 gauge wire. Many perhaps tried passive surround decoding in the pre-discrete days. If they fooled with the lower gauge wire, they would have experienced failure in getting that circuit to operate.
    I also tried 20 gauge wire. The tonality of the sound of the whole sound field was thin, much like turning down a treble control on a receiver counter clockwise.
    When it comes to an active discrete surround sound receiver as we have today, I cannot really comment on the effects of lower gauge wires since I did not have the opportunity to try that. My brother does have 16 gauge wire on his home theater system and it appears to work well. I have 18 gauge wire on mine and I am comletely satisfied as to its toneality and soundfield balance.
  8. #7
    gene's Avatar
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,818
    Thanks Given
    819
    Thanks Received
    2,401
    Default
    You may wish to rethink that as 18AWG wire has nearly 4x the DC resistance of 12AWG. Thus running 20ft of 18AWG wire would yield the same resistance of nearly 80ft of 12AWG!
    insertion loss of 20ft of 12AWG with 8 ohm speaker = .07dB
    insertion loss of 20ft of 18AWG with 8 ohm speaker = .28dB
    The minor additive AC resistance of 12AWG wire at 20kHz is completely washed out by the DC resistance of 18AWG wire so even at frequencies up to the capabilities of human hearing, 12AWG wire still has FAR lower AC resistance, about 2.3 times lower as a matter of fact!
    Gene DellaSala
  9. #8
    yepimonfire is offline Audioholic General yepimonfire is looking for a job at AH
    Join Date
    Jan 2010
    Location
    Not Massachusetts!
    Posts
    1,341
    Thanks Given
    137
    Thanks Received
    87
    Default
    i used to use really skinny wires, i think like 18 or maybe even 20 gauge, i bought some 16 gauge and wow what a difference, not only in loudness, but fullness of sound, the sound seems to have more depth where-as the 18 gauge made it sound "squashed".
  10. #9
    j_garcia's Avatar
    j_garcia is offline Seriously, I have no life. j_garcia should be listened to
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,285
    Thanks Given
    1,664
    Thanks Received
    3,805
    Default
    Quote Originally Posted by yepimonfire View Post
    That means the previous wire was insufficient for the draw of your speaker.
    HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
    System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
    Are you sure which side of the glass you are on?
  11. #10
    jmwsaw is offline Audiophyte jmwsaw is a forum member in good standing
    Join Date
    Dec 2010
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Default Does solid core speaker wire matter?
    I'm a novice audiophile and working on my first true home theater set-up. I've been wading through endless opinions about the "right" type of speaker cable for an in-wall install. I just read your article about gauge size, but what about the differences in solid versus stranded cables? Does the use of solid core have any measurable effect? Would that reduce the need for heavier gauge wire?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
