newfmp3 said:
how much manual adjustment is available with ypao? or does it differ from model to model?
It's a very valuable feature.
Although, it's not perfect, I still go into the manual mode and tweek after I use YPAO, but it's awesome as far as a starting point.
I can't imagine how much time and headaches there would be without it, actually.
It does a fantastic job setting up EQ, speaker size/distance/level, and detecting what you actually have hooked up.
As far as manual set-up goes, you have full customization there, and you can use the Auto-setup and then go into Manual setup to tinker with levels, distance, etc., everything you could do if you didn't have YPAO ( I find for me it sets the speaker distance farther than they actually are, and the surround L/R speakers are a bit on the subtle side)
So really there's no reason not to want this feature. The mic should be placed at ear level in the postion of the room that you would be listening (don't worry about the wife
) and can even be tripod mounted.
But yeah, from my experience, I would really label it "invaluable", honestly.
