Thanks for the input, I'm still researching the maggie speaker's.......do like the Yamaha - is there a Yamaha that can handle the maggie's?? is the 1020 a "good receiver" or do you recommend a better option.... is the maggie's a good option or better to go a different route......500.00-to 800.00 for receiver..... 500.00 for speakers..
Thanks very much
The RX-A1020 is a good receiver. Going up primarily gives you more features (for example, better video processing in the RX-A2020, which will only matter if you need such processing in your receiver; your TV does such things, too). The power output will not be dramatically higher with going with a higher receiver. If you are looking at a total of $1300 for a pair of speakers and a receiver, the Magnepan MMG would be a good choice, provided one is not wanting to listen at deafening volumes. That would leave you only $700 for the receiver, so you would have to drop down a level to keep on budget.
The main thing to consider when buying a receiver is to get a good brand (Yamaha is good), and then get the features you need. Going higher gets you slightly more power (usually, though not always, an insignificant increase in power) and more features. If you want high power, buy a receiver with preamp outputs, and then buy a separate amplifier for that high power. Obviously, that increases costs considerably, but you do not need to replace the separate amplifier when you decide you need new features in a receiver later on.
At moderate volume, the Yamaha will drive Magnepan speakers. But not at very high volume, particularly for an extended period of time. Here you can see some measurements:
Yamaha RX-A1020 A/V Receiver HT Labs Measures | Sound & Vision
If we look at the specifications for the MMG:
