This is my first post, but hopefully someone here can help me out. I have a Yamaha RX-V592 that worked great for a few years. A few months back our house was hit by a lightning strike, and this receiver stopped working. However I would like to use it elsewhere and need to find a way to get it working.
When plugging it in, and hitting the power button, one of several things happens.
A) It clicks twice and does nothing (needs to be unplugged after).
B) It clicks, the screen comes on, but it is filled with all the symbols. Won't power off without unplugging it and pushing buttons does nothing.
C) It turns on, can switch between inputs, then turns off suddenly.
These are basically the three scenarios that happen, but it seems to not be totally dead. Does anyone have any suggestions what to do? I have looked at the one fuse I can find (near the plug), however it seems to be ok. I have read about factory resetting the unit, but can't find instructions anywhere in the manual. Any suggestions or help are appreciated. Thanks.
