Hi again people, i've just finished the install of my system. (yamaha rx-v475+p363/PC351/p153)
It sounds great, but i have this noise issue. When i'm about -15db and above of the receiver volume, it begins with this frying or raining noise.
This may be "similar", but not quite the same i guess:
https://www.youtube.com/watch?v=qLeEh-wIOAY
The receiver's source is my PC directly via HDMI from my video card (nvidia gtx680).
The problem is exclusively from the sound, if i plug some "hdmi out" from the receiver, the imagen is flawless.
If i mute the PC, it still makes the noise, but if i mute the receiver or unplug the hdmi, it doesn't make anymore noise.
The noise comes from all the 5.0 speakers equally, and i've tried 3 hdmi cables already and different hdmi outputs from the video card.
I will REALLY apreciate any help on this.
Thanks in advance.
Regards from Argentina!
Edit: If i activate "direct mode" the noise gets lower.
This is the description of the direct mode (or direct playback)
"when the direct playback mode is enabled, the unit plays back the selected source with the least circuitry in order to reduce the electrical noise from other circuitry"
