My Yamaha M-70 (2-channel outboard amp) is acting up. The first one I bought seven years ago off ebay still works great. However, my second ebay M-70 purchase started acting up a few weeks after purchase.
Specifically, the protection light started going on, even when not playing. I was hearing popping sounds from my rears, which it powers, even when the pre- was turned off (I leave the amps on--every time they turn on I have to reset the breaker). I noticed the protection light was on, so I turned the amp off.
Today I checked a few things. First off, I noticed when I touch the connections running to the pre-amp, it made a loud popping noise. I turned it off again, checked the speaker wire polarity, and changed the RCAs. After resetting the breaker, it played for a bit, with the protection light on--then just as I was going to turn it off, the speakers stopped making sound. It doesn't seem to work at all now.
I am just about certain I will need to spend money and have someone fix it, if it is fixable. However, if anyone knows an easy fix, I would be most happy. Short of that, it would be nice to know the likely issue, so I can research how much it will be. Lastly, I am in the Tampa Bay area--if anyone knows a good electronics shop with knowledge of the old Yamaha M- series, I would be ecstatic.
