Here we have one of the new line of Yamaha Amps with its slick styling. Are you interested in the? Ill post the rest of them soon.
A-S801
MSRP:$999.95
Minimum RMS Output Power (8 ohms, 20 Hz-20 kHz) 100 W + 100 W (0.019% THD)
High Dynamic Power/Channel (8/6/4/2 ohms) 140 / 170 / 220 / 290 W
Damping Factor 240
Frequency Response 10 Hz - 100 kHz +/- 1.0 dB
Total Harmonic Distortion (CD to Sp Out, 20 Hz-20 kHz) 0.019% (50 W / 8 ohms)
Signal-to-Noise Ratio (CD) 99 dB (input shorted, 200 mV)
Audio In / Out 8 / 2
Digital Input Yes (optical / coaxial)
USB Input Yes (type B)
Subwoofer Out Yes
DC out Yes
Pure Direct Yes
ToP-ART Yes
Switchable CD Direct Amplification Yes
Standby Power Consumption 0.5 W
Power Management (Auto Power Standby) Yes
Dimensions (W x H x D) 17-1/8" x 6" x 15-1/4"
Weight 26.7 lbs
Technology
ToP-ART
When processing and transmission of the audio signal is simple and direct there is less chance of it being affected by noise and distortion. Yamaha’s amplifier design technology called ToP-ART (Total Purity Audio Reproduction Technology) features I/O (input to output) Direct Symmetrical Design, with left and right channels organized in a straight, symmetrical layout for highest signal purity.
CD Direct Amplification Circuit
Auto Power Standby
When Auto Power Standby is engaged, the amplifier will automatically shift itself into standby mode when a user function has not been executed in eight hours. This a great function if you forget to turn the amplifier off and it will help minimize power consumption when the unit is not in use
Engaged by a front panel switch, it matches CD signal levels so each stage produces less noise, resulting in improved S/N ratio and maintenance of the amp’s total gain balance
