Hopefully somebody here can help me with this quandary. I have a Niles MRC-6430 (Auriel) system, and love it, but am looking to put some outdoor speakers on it and cabling them is ... difficult.
We have an enclosed area between our house and garage, and want to get audio there. Putting the speakers on the house is darn near impossible to run cabling to just the speakers (the wall carries a LOT of load), so that leaves attaching them to the garage side, which is very easy to drill through and mount speakers to. The problem is, how do I get the audio to the garage?
The only wires I have run are power, and I also have IP connectivity with 100+ Mbps to there (I can get that to be Ethernet if that's the best choice). I'll install an amplifier in the garage to handle that, but how do I get the two RCA connectors carrying audio out there?
I've found some long discontinued powerline options that are unavailable, and also low latency long range Bluetooth, and then above that we're talking about very expensive professional options. I'd prefer if possible to not do wireless, as it would go through two exterior walls (one uninsulated without sheetrock) to get there, and I already have very busy wireless. What's the most reliable way to get signal there with good quality? Audiophile is definitely not required, but reliable CD quality would be fantastic.
Thanks in advance!
