way to upgrade hometheatre system without changing audio equip?
ats888
hi
is there an easy way to upgrade the home theatre/surround sounds side of my system without compromising on the audio side and without completely new amp/speakers? Surround sound processer, second amp, second set of speakers? powered sub?
I currently have
Rotel RCD991 (balanced, coax and optical digital outputs)connected with TRANSPARENT THE LINK 200 INTERCONNECTS to a
NAD C370 (120W Integrated but can be used as either a pre-amp or power) with silver something or other speaker cable £5/m to
Castle Harlechs 150W (first series) on spikes
Sony minidisc player
Cyberhome DVD player, basic scart to tv, basic gold plate interconnects to Amp
Toshiba V-652UK VCR player, normal aerial cable to tv, basic gold plate interconnects to Amp
Sharp tv (60cm perhaps)
Greatful for any advice
Thanks
Andrew
markw
I'd vote for a powered sub. Properly integrated, it will add a solid foiundatiuon to what you already have.
Rip Van Woofer
Rip Van Woofer
Room acoustics!
Also, one of those cool popcorn machines! ;)
