Hz are another way of saying "Note"
The lower the Hz, the lower the note.
A subwoofer rated to go to 20Hz, will play lower then a subwoofer rated to 25Hz.
The human ear can only hear from 20Hz to 20Khz(the K means Killo, as in 1000, so 20Khz = 20000Hz).
Once subs Frequency responses go Below 20Hz, your really start to feel the bass because it is now inaudible to the ear.
All speakers should be able to play from 80Hz to 20Khz. If they can't, you should look at getting something different. Subwoofers are different. I personally say if it can't play 40Hz, its not a subwoofer. If I was you, I would look for response into the 20's in Hz.
SheepStar
