Trouble with Bowers and Wilkins 804 D3
shadyJ
Speaker of the House
Staff member
Unfortunately until I can build a dedicated room my current set up is in a 17’ x 50’ room with 9’ ceilings that is also open to another area on one side. Sitting about 15-16 feet away
Music is about -20 when playing
But I’m a sucker for good action movies so it does tend to stay around 0 when the action is going on. There’s something about when a gun is fired and feeling it like your in the room with it. Hence the dual svs subs
I would 100% agree when I hear them in a show room in an average listing environment 0 is crazy loud! :D
How are you blowing the bass drivers when you are using subs? You are high-passing the main speakers, right?
Turk
At 80hz
But apparently my audyssey is trying to over correct around 100-200hz
Turk
It boosted 65-80 hz too , to one of the front channel by 8-9 db .
I’m kinda new to this but how would it boost that low if crossover is 80hz?
I thought audyssey took measurements for everything but didn’t actually apply it that low. At first it set speakers to large but I changed it to small with a crossover at 80
No, It will boost regardless but setting the channel to small will cause frequencies above XO (80hz in this case ) to be redirected to the sub. As I explained before, crossover is not a brick wall so with 9db boost the channel affected will still get a fair bit of 80hz and slightly lower freq contents even with XO set to 80hz. Again, this of course should not be a problem at all by itself, but everything else , that is , large room , sitting 16 ft away, listening at 85db average , boost in the mid bass , inefficient and small woofers that cannot take the heat and/or excursion when being pushed to produce very high instantaneous spl at your seat all add up to cause trouble .
Turk
I believe I can build my theater room in the basement for about 1/4 the price of the 800 d3’s that TLS Guy suggests. I know the 800’s are awesome but the wife would never go for it. And the theater im going to make small about 13’ x 10’ with 8’ ceilings maybe a little smaller and then I think the 800’s might get a little over powering and the 804’s should work just fine.
That sounds like a really sensible plan.
By the way, do not use Audyssey. That is a massive sound quality spoiler. Your speakers will sound much better without it. It also wants to use Audyssey Dynamic Eq, which is a real rogue program. The also, among other ills, gives a big gratuitous bass boost in the last octave. It absolutely should not be used with speakers of the quality of your B & Ws. That will be a massive downgrade.
The only good thing I have to say about Audyssey is that it is an accurate tape measure.
You can read my three part write up on Audyssey here.
Turk
That’s an expensive tape measure :D
Turk
Just reading the first part of your part 3 on audyssey I noticed it was crossing everything at 200hz about. Did you try a second mic by chance? I have that issue with one of my mic’s no matter what room or where it goes it crosses everything high but when I use one of my other mic’s everything measures fine.
No the stupid program got confused by a room null on the center channel. I was able to trick it by boosting the BSC by a few db. Anyhow keep reading.
Mr. BLH
I'm having the same trouble with my 804 D3. I have a mid sized room and use the B&Ws for music and as the fronts of a 7.1 surround system. I have an Anthem MRX 720 as my reciever with a Panamax M5300-PM as my power management system. My amp is a McIntosh MAC6700 and my server is a Sony HAP-Z1ES. When I listen to music, it is just a 2 channel system. The Mac puts out 200 watts/channel which the B&Ws supposedly can handle. On a volume scale of 1 - 100 I've never been over 43. Why are the drivers failing?
Side note: everything was installed by a B&W diamond dealer.
So the Sony Server connects to the Anthem 7.2Ch Receiver which connects to a McIntosh 2Ch Receiver which connects to the B&W 804D?
Why didn't you get a regular McIntosh Amp, instead of a Stereo Receiver?
As pointed out on this forum many times, volume position does not mean much by itself. For example, if the input signal is super strong, even at 43/100 can cause the amp to max out and clip. You can either take some measurements, or use a good online spl calculator to figure out the actual power output to the speakers.
Yes, you need to explain why you have a receiver connected to a s receiver and how.
The reason these speakers are failing is because people are playing the wrong sort of music too loud.
I think from the design of these speakers their primary purpose should be the reproduction of classical music.
