OK, so this may not be a typical receiver related question, but I am still trying my luck. I have a Yam HTR5760 which I bought in Canada which I have now shipped back to India along with myself
To make it work here in India, I need to buy a step down transformer since the voltage in India is 220V. When I went out the local market on my hunt for a transfomer, I was told that the one other consideration to keep in mind is the power requirement of the receiver. So I went back to the Yam site and here's what I got.
http://www.yamaha.ca/av/Receivers/Back_Panels/HTR_5760_Back_Panel.asp
This is the picture of the back panel which states that the power requirement is 370W.
According to the yamaha site FAQs, I need to add 25% to this and then buy a step down transformer that supports this power. They also mention that I should not buy a converter or an inverter. More details on
http://www.yamaha.com/yec/customer/faqs/general/faq20b.htm
Here are my questions
1. What is the difference between a convertor and a transformer?
2. If I buy a 1000W step down transformer, will the receiver still work?
3. If I buy a 1000W step down transformer, and if the receiver only requires 500W, then can I connect my subwoofer and DVD player to the same transformer (provided the net power requirement is <1000W)
4. Is there any way that damage to the receiver is possible if I choose an incorrect transformer? I am OK if the transformer blows up, but what I don't want is my receiver blowing up.
5. How can using a converter or an inverter damage the system?
I know that this is not a typical receiver question, but if anyone has any information, please help.
Thanks
