I happened to just today receive a "broken" SU-V55A. It appeared not to be broken, just the power switch knob was missing, so that it was difficult to poke the lever thorugh the small hole where the knob used to be.
Anyway, I took it apart just to clean the innards and to be frank, I didn't see any fuses. It's unlikely there are no fuses, so perhaps they are hidden quite deep inside.
It's quite a nice machine, good sound and enough power, don't throw it away to quickly. There's not so much that can break, these amps are made quite solid. Well, unless there have been preliminary signs (heating up too much is the worst).
First thing to check is whether the sound of a clicking relay can be heard when switched on. If so, also the "current drive" light should switch on (next to the voltage control light). If both work most likely it's something simple; speaker switch not on or on B while speakers on A. Another possibility is dirt in the switches or potmeters. What will help sometimes is engaging them a couple of times.
If only the voltage control light comes on, then the trouble is more serious, professional advice then might be needed. If no lights at all come up the net cable/connection should be tested.
If needed I can send the service manual of this machine, then send me a PM
