System opinion and some questions
trident922
This is my system I put together :
Denon 2805
Main speakers Wharfdale Valdus 500
Surrounds and Center Infinity primus
Subs Velodyne CT120 Yamaha ystsw60
Monster Power HTS1000
The question is would I be able to use both subs and if so how to set the crossover. Would it also mess with the auto setup. :)
JoeE SP9
JoeE SP9
IMHO using both subs is not a good idea. Having two different speakers doing the same thing is not a good idea. Sort of like having a JBL for the left main and a Polk Audio for the right main. Either one can be very good when paired properly but not when mixed. :cool:
Denon 2805
Nothing will be lost or damaged to try the two subs, even if different. Switch it in, then out, see if it makes a difference to you. Best if both are in the same corner.
JoeE SP9
JoeE SP9
Never thought it could harm anything. Although I wonder how the auto setup would work (what the results would be) with both connected simultaneously. Placing both in the same corner could lead to some interesting cancellations and reinforcements. :cool:
Not according to published papers on this. Tom Nousaine actually recommends this approach over multiple corners.
dsa220
dsa220
Depends on how you plan on using the two different subs. I have two subs from two different manufactures (REL and AudioSource). I use the REL to augment my B&W's and use the AudioSource as my LFE sub, this way when I listen to 2-channel audio I have good, clean and deep bass without the boom or bloom; and then when I watch a movie I have that extra punch that can be required with certain movies. Give it a try, you may like what you hear.
trident922
I just fininished watching phantom menace and I am amazed how much better the denon sounds over my sony.
