SVS PB12-NSD Subwoofer Review
Discussion in 'Subwoofers' started by admin, Feb 5, 2012.
  1. admin Audioholics Robot Staff Member
    admin
    Apr 16, 2004
    172
    1,617
    SVS has long been known for high performance subwoofers and the PB12-NSD while the most cost effective vented subwoofer in the current line up, still musters up a hefty amount of room filling bass. (Also offered is the PC12-NSD cylinder version which is said to have nearly identical performance.) Tipping the scales at 66lbs the heart of the PB12-NSD is a quality 12" long throw, aluminum cone driver vented through a 4" diameter flared port, all housed in a large, well braced, black vinyl wrapped enclosure, which happens to be the only finish option available. The brains of the operation come from a 400 watt version of SVS's Sledge amplifier platform. This combination available shipped to your home for $769, provides extension with authority to 20Hz and perhaps a bit lower in some rooms. Build, performance and parts quality for this price range were all found to be exceptional. While the PB12-NSD is short on finish options and may not have some of the extra bells and whistles offered by other subwoofers on the market, what it does do very well is the task of producing accurate and powerful bass with depth and finese that most other subs in this price range cannot match, as evidenced by the PB12-NSD achieving the Audioholics Large Room rating. At the end of the day that is what a subwoofer is supposed to do and the PB12-NSD does not disappoint.
    [​IMG]
    Discuss "SVS PB12-NSD Subwoofer Review " here. Read the article.
    • Like Like x 14
  2. Adam Audioholic Jedi
    Adam
    Jul 5, 2006
    32,075
    11,912
    Tucson, Arizona
    Great review - thanks! I'm glad that AH and SVS are friendly again.
    Any chance of reviewing one of their cylinders, as well? While they are reported to be very similar, I'd love to see an apples-to-apples comparison from AH.
    Adam,
  3. gotchaforce Junior Audioholic
    gotchaforce
    Jul 27, 2007
    92
    20
    Its amazing that no other website has picked up a guy like ricci before... these tests are invaluable for internet direct subs and showing which sub is worth their salt.
  4. cel4145 Audioholic
    cel4145
    Nov 29, 2011
    198
    26
    Very good review, so I'm not complaining. The review has "fit and finish" listed twice in the report card at the end. Should one of those have been "features" like with some of the other reviews?
    • Like Like x 1
  5. Nuance AH Audioholic General
    Nuance AH
    Aug 29, 2008
    1,085
    402
    Wisconsin
    Thanks for the review fellas. SVS' never ceases to amaze me!
  6. Fowl Audioholic
    Fowl
    Jul 29, 2007
    230
    22
    Me too, I have two of these subs in my current room, and I love them. Good job SVS.
    Fowl,
  7. FirstReflection AV Rant Co-Host
    FirstReflection
    Aug 3, 2008
    1,260
    887
    Another great review of another great SVS sub!
    It's obvious SVS has gone for linearity with their current lineup, even of it means they can't boast higher output levels at only a few or a small range of frequencies ;)
    It's interesting that if you look at the 20Hz output, each step up in model basically adds around 3-3.5dB more output. The NSD at around 103, the Plus at around 106-107 and the Ultra at a hair over 110. Might not seem like much, but it's literally a doubling of power. It's just interesting to note that you can basically move up in the model lineup or get a pair of subs that are one model down. And the prices sort of track with that too. Makes perfect sense, really ;)
  8. Marshall_Guthrie Audioholics Videographer Extraordinaire
    Marshall_Guthrie
    Oct 5, 2007
    395
    164
    Willamette Valley, OR
    Josh did great work at a couple forums before coming to audioholics. I'm glad he's chosen to make audioholics his permanent home.
  9. Marshall_Guthrie Audioholics Videographer Extraordinaire
    Marshall_Guthrie
    Oct 5, 2007
    395
    164
    Great review. I was an early owner of this sub and your observations match my own. I didn't have the guts to take mine apart though for fear of bending something up :)
    One suggestion: you may want to note the model number on the Tabbed Measurement Data as "PB12-NSD (2011)" or similar as SVS has been updating their models every couple years without much in the way of model number changes. People logging in to view your data may confuse it with the previous model.
    Keep up the stellar work.
  10. homwerk Audioholic Intern
    homwerk
    Feb 1, 2010
    28
    0
    this is a great idea. I had to double check when I was comparing this data to some of the other subs that were reviewed.
  11. DS-21 Full Audioholic
    DS-21
    Aug 10, 2011
    493
    185
    A big amp, big vented box, and Peerless XXLS12 adds up to a good sub. Who woulda thought! :)
    Actually, someone did, a while ago.
    That was the sub that won the old Keith Yates Way Down Deep comparison.
    Four of these SVS subs will likely be quite close to that, based on drivers used and amplifier power. Maybe even a smidge better, unless the Gennie amps have higher peak power.
    And be about the same gross volume in the room.
    So the big difference is that the Gennie is about 10 grand (and, being a single unit, harder to schlepp around) while four of these subs are less than a third as much. (And no less attractive, really.)
    Nice job, SVS!
    • Like Like x 1
  12. pbc Audioholic
    pbc
    Oct 23, 2006
    191
    80
    Awesome review as usual Josh. Interesting, looks like a 2 to 3db difference between SVS's numbers at 25/31/40 vs Ricci's, while the rest of the range is within 1 - 2 db?
    pbc,
  13. Ricci Bassaholic
    Ricci
    Jun 16, 2011
    88
    116
    Louisville, KY
    Yes I noticed this and it was mentioned to Ed. I tried a couple different gain settings on the subwoofer as well and it didn't make a notable difference. Ed mentioned that SVS had made some changes to the DSP settings in the PB12-NSD since their internal test data had last been collected on this model so that might explain it. Then you have the usual disclaimers about different day, sub, equipment, calibration, atmospheric conditions, etc. I'm confident that the data from the review is accurate for that particular unit. Ed didn't seem particularily concerned with it either. 1 or 2 dB is still a rather small delta.
    • Like Like x 1
  14. Marshall_Guthrie Audioholics Videographer Extraordinaire
    Marshall_Guthrie
    Oct 5, 2007
    395
    164
    If I'm looking at the same chart you are, it appears that Josh's numbers also represent lower distortion. Maybe SVS tweaked the EQ to reduce distortion at the expense of output?
  15. Ricci Bassaholic
    Ricci
    Jun 16, 2011
    88
    116
    Louisville, KY
    That was sort of what I was thinking as well.
    SVS seems to thoroughly vet their subs before they ever get out into the wild but you can only do so much. Some end users just seem to have a knack for dropping signals into them or otherwise taking subs to places where the manufacturer never quite got them to. ;):D. At which point SVS might receive some feedback and decide to make a tweak or two to add just a little more protection. ( This is all complete and utter speculation on my part by the way.)
  16. alexend Audiophyte
    alexend
    Feb 15, 2012
    2
    0
    Nice review Josh, I was waiting for a review of that sub from audioholics.
    I'm also hopping that you would review the PB12-NSD little brother, the SB12-NSD. Is that a probability for the near future?
    Thanks
  17. Jack_O_Lantern Audiophyte
    Jack_O_Lantern
    Feb 14, 2012
    4
    0
    Just ordered mine. I can't wait.
  18. KalaniP Audiophyte
    KalaniP
    Oct 14, 2011
    9
    0
    Thanks for the great review! I love to see more praise heaped on my sub of choice. :)
    Now we just need a true head-to-head against the competition to truly place it! I'd be especially curious to see it pit directly against the Outlaw LFM-1 EX, which, once shipped, prices out pretty darned close.
    And now, back to saving my pennies for a second PB12-NSD...
  19. Ricci Bassaholic
    Ricci
    Jun 16, 2011
    88
    116
    Louisville, KY
    The LFM-1-EX has already been reviewed and put through the same objective measurement process.
    Also I would not be surprised if the SB12-NSD ended up with a review in the next couple of months.
    • Like Like x 2
  20. Marshall_Guthrie Audioholics Videographer Extraordinaire
    Marshall_Guthrie
    Oct 5, 2007
    395
    164
    Yes, the outlaw hit higher max SPL at the expense of accuracy. I had considered the outlaw, considering the aesthetics and especially when priced on sale, but I chose the SVS because of SVS's reputation and care for their customers, and because the quality of my dBs was more important that the quantity :)
    Now, that's not to say that I didn't leave a corner free for a 2nd PB-12, I just need to get the projection done first.
Share This Page
  • CEDIA
