I'm not hurting for bass. I just thought Bagby had some magic reason for choosing that combination. I currently have the 12" ultimax in a 2 cu ft. sealed, hooked up to a inuke 3000dsp. It's has a wide range of behavior options available with that amp, I am finding, as I poke around the settings. My room also has a lot of gain, which is why I am getting away with using only a 12" driver. It can actually get quite ridiculous in here and as it is, I am at about -6db on the gain setting.
So far, the best setting combined with the Tempests seems to be about 1.5 x the lowest rating of those, which is about 38hz, IIRC, which has me running the sub cut off at about 50-55hz since the sub has to be placed relatively close to the main speakers. The Tempests have such a good sounding mid bass down into the 40's it's a shame not to exploit it. I have tried all the other suggested typical crossover points, mains large/small etc.
I also have a RSS315HF-4 that I can try for a different flavor. I just don't have a lot of placement options. As it stands, I can rattle the interior doors in here if I really liked a lot of bass, but this seems to be the most natural sounding, and things like bass guitars sound live, like they are hooked up to a bass amp in my living room.
