Hi everyone,
I’m thinking about replacing my old home stereo with something new. I view/ listen to everything via my computer (I have 2, one is a server). I’m setting up for stereo + subwoofer now, but I’d like to be able to expand to 5.1 at some point. This is what I plan:
1. Because my two computers are a little noisy and ugly (they’re big rack mountable beasts) I figured I’d banish them to the room above the living room (where the action will be).
2. Since it’s going to be noisy up there anyway, I think I’ll go for a pro amp since they have good bang for the buck, just loud fans. Probably the QSC RMX 1450.
3. Need a reasonable DAC that at some point can do surround sound. The Audiofire 8 seems like a fun choice.
4. I’ll wire everything through the walls to faceplates, with the LCD on the wall.
So now my question: The audiofire has 8 balanced outputs. Two of these go to the amp, which will output Speakon connectors downstairs. What is the best way to get a signal to my sub? Should I take a balanced line level from the audiofire down to the RCA sub input (do I need a crossover, or will the one on my sub work?). I know the audiofire decodes surround (which again I may use at some point), but can’t figure out how it handles the sub out.
I welcome all ideas/ comments including the ones that think this entire setup is misguided at best, criminally insane at worst.
Thanks!
Cisco
