Split satellite signal via coax to two tvs??..
Discussion in 'Televisions & Displays' started by Pwner_2130, Oct 25, 2007.
  1. Pwner_2130 Audioholic
    Pwner_2130
    Apr 18, 2007
    173
    3
    Hi,
    I'm not sure if this tread belongs here, but I was wondering if anyone here knows how to split a signal from a satellite out to two crt tvs? I 've tried splitting it with an RCA coax splitter to no avail...Please help, thanks:D
  2. jonnythan Audioholic Ninja
    jonnythan
    Jan 20, 2006
    3,174
    455
    Satellite? Like.. DirecTV?
  3. Pwner_2130 Audioholic
    Pwner_2130
    Apr 18, 2007
    173
    3
    Yes, Direct TV
  4. jonnythan Audioholic Ninja
    jonnythan
    Jan 20, 2006
    3,174
    455
    No, you can't do that. For that you would need two receivers and a dish with two... receiver beacon thingies on it.
  5. Rickster71 Audioholic Spartan
    Rickster71
    Jan 15, 2006
    7,147
    4,480
    N.J.
    You could split the 'output' from the sat receiver to the TV's.
    They would both show the same channel though. That's no fun.
  6. Rickster71 Audioholic Spartan
    Rickster71
    Jan 15, 2006
    7,147
    4,480
    N.J.
    I have Dish Network, and split my family room Sat receiver's output, and sent it to a kitchen TV.
    My Dish receiver has an RF remote, so I could change channels while watching the kitchen TV.
    You can't use just any splitter though. It has to be rated at the higher frequencies that the satellite signal demands.
  7. BMXTRIX Audioholic Spartan
    BMXTRIX
    Sep 16, 2004
    6,438
    1,631
    Chantilly, VA
    Where are you trying to split it? What exactly are you trying to accomplish?
    If you are simply using the modulated output (on channel 3) then, yes, you simply put a splitter in place and it will send channle 3 DSS to wherever you want it to go.
    I did a setup recently with a Dish box (channel 4) and DirecTV (channel 3) and I combined/split the signals to 2 TVs so they could watch either box they wanted to. Worked absolutely great!
    As for the incmoing line - you should be using a multiplexer of some sort. I'm not as well versed in the nuances of the incoming satellite signal to multiple boxes, so I'm not going to be much help there.
Share This Page
  • CEDIA
