the speaker wire won't change the sound UNLESS it is too small a gauge for your length of run. so you can get ANY 12 gauge or 14 gauge cable and rest assured, that's the best sound you can get from ANY wire. of course, that's if your runs are reasonably long. i'm sure somebody else will chime in the max length for each gauge when there is but a tiny bit of attenuation that starts.
