That's brilliant. So you conclude that my measured data must be all wrong because I witness something that you either don't understand or have never witnessed yourself.
Measured data on what, speaker cable break in? Hmm since I have over 100k worth of test gear to measure cables, along with a fairly decent EE background with a BSEE, I think I have a basic understanding of electrical theory and it applies to cables.
Perhaps you should do a little reading yourself:
Audio Cable Break In: Science or Psychological?
I guess next you'll tell me that capacitors don't burn in either, or that all power cords are the same, etc.
Why are you attempting to compare capacitors with a passive element such as wire? This is the typical straw man argument used by cable snake oil vendors. Surely you have more common sense than that to differentiate the difference between the two? I know, don't call you Surely
As for power cords. No they are NOT all the same. Some esoterics are really poorly designed and DON'T even have UL approval. As for their sound, only poorly designed power cords are sonically distinguisable on poorly designed esoteric gear.
Maybe you should also spend some time discussing these issues with industry professionals. I don't mean those that sell wire either. I am referring to those that manufacture wire.
Actually I do. Does the name Steve Lampton from Belden ring a bell? Perhaps you aren't aware of many of the co-authored articles we did for several pro print publications like Pro AV. I don't want to put words in his mouth, but he and I are pretty much on the same page just like every other credible electrical engineer when it comes to cables.
As for other industry professionals, how about Henry Ott and Dr. Howard Johnson?
Perhaps you should check out some of our cable articles that they contributed to and also peer reviewed.
Audioholics Cable Articles
Maybe you know of a guy that will state for you that the dielectric constant of the coating of the wire will stabilize in the first ten seconds. That would make sense right?
Well I know of some companies that slap batteries on their dielectric to supposidly stabalize the dielectric. LOL good show
Perhaps you should check our our cable solution. We spank those electrons that misbehave
Audioholics GLOB
I'd also encourage you to read an article I authored on Cable Dielectrics:
Dielectric Absorption in Cables
