Sound quality issue
  • Thread starter Thread starter fatalwounds
F
fatalwounds
2
0
0
So I have hooked a couple of loudspeakers up to an amp, and the right speaker sounds kind of bad. I also noticed that one of its cup things is sort of imploded. If I find a way to pop it back out would it sound better or did I just hook it up to the amp incorrectly?
Thanks
Be more descriptive. Bad is a very general term. Also state the speaker make and model, for all we know it could be a "bad" speaker.
By "imploded" I'm going on a limb and guessing you mean it looks like someone poked it in with a finger. Leave it, assuming it isn't torn open it won't really affect the sound of the speaker. If you so desire you can always get it replaced or do it yourself.
By bad I mean it sounds very muffled and there is very little treble regardless of the EQ setting. They are Yamaha NS-A220 speakers. Since the cup thing being poked in isn't the problem I'm going to guess that it's the individual speaker that's broken. Thanks for the info
Not necessarially.
Just because the cap is poked in doesn't guarantee that there's no other problems. From your description of the sound it sounds like the tweeter might be shot.
Plus, you don't say which speaker is "poked in".
Ya, it sounds like a blown or partially blown speaker. If you feel it's worth trying to fix/replace I'm sure you can find replacement speakers on ebay relatively cheaply.
If the tweeter is pushed in, the smallest driver on the speaker, and the sound is muffled, then chances are that tweeter is totalled. Put your ear up to each driver and determine which ones are working and which aren't. The amplifier probably is not the problem.
